Well In the Big Ar thread I showed the Cover made by JnB Audio on E-bay. Just great work!!!
I added some constant torque hinges made by SouthCo , they are from the E6 series. The first ones I got were 20lbs of force I thought
might be too much but now after using the 8 lb smaller ones the 20 pounders may have worked just fine.
Being paranoid I added an aluminum plate on the inside of the cover for each hinge to spread
the forces over the acrylic. Drilling the holes in the cover went with out a hitch, just got slow.
The cover stays where you put it after about 45° where if you go lower it will fall. They gave bump stops for the four corners which is a nice touch.
So here are some pics.....
Athanasios
Athanasios
