KNielsen
Well-Known Member
Hey AK.
I want to share this project as this might inspire others to either restore or make the fully rebuild.
It should be mentioned that the Aragon 4004 in this thread is built by request, soo..... -some parts cannot be selected otherwise, as this is a request by the customer.
The most common parts selected are Dale, Nichicon, Kemet and Wima. So should be ok, even if "we" like other stuffing.....
But for now, this is our plan:
4004 restoration throughout including converting to 4004mk.ll (schematics are available for this step, and added in this post as PDF), and a 8008 PSU regarding e.caps size (not xformer).
A new thermistor will accommodate the bigger e.caps.
All 1/4w resistors are changed to Dale RN60, all driver transistors changed and maby the powertransistors is replaced. This last part with the powertransistors I'm not that big of a fan of; the emitter shows a differences of maximum 1mv in the original condition, but the owner feels that these MJ21xxx should be replaced while the amp is here for a restore, and this I fully understand.... Please comment on this if you have second thoughts, and find this a good investment regarding powertransistors or not??
Other inputs is also very welcome, so please share while building this one.
I'll post as progress
