mondialfan
Well-Known Member
The mk.1 DC protection schematic
There's has to be an error in this schematic. Q101 & Q102 should be tied into the circuit to trip the relay (base of Q104) but they're not.
Correct....! My fault.... I edited the schematic a couple of times to make the layout more readable but forget to tie these up again... I correct this and post the schematic againThere's has to be an error in this schematic. Q101 & Q102 should be tied into the circuit to trip the relay (base of Q104) but they're not.
Thanks. It's a fun build, and listening to the amp before I took it apart, I'm really excited to hear the final result when finished.Really nice work, and great thread. Thanks for posting it.
The schematic doesn't show any Zobel???
Is it the one located underneath the heat shrink between the speaker binding posts?
And if values are NOT according to the normal 1.5ohm/0.22uf that Mondial uses in their later models, should I change this to the newer standard?
Do you know @mondialfan ?
Thanks for reply... I opened the packed and did find a Dale 5ohm, 5watt/0.1uf, 200vdc Zobel... The amp seams to work well with this setup, so I'll leave it intact.There should be no Zobel from the factory. If there is one it was added by a previous owner. The presence of a zobel is not a bad thing. This thread at diyaudio discusses the lack of a zobel in the Aragon and the possibility of adding one. Many amps use a more generic value for the output zobel of 5ohms and 0.1uF and sometimes 10ohms and 0.1uF. In fact if you pull up enough schematics of various other manufacturers amps you'll see those values on the output a lot. Mondial must've come up with their values on the Acurus amps with some experimentation as to what worked best. Also see section 3.4 in this article from Rod Elliot.
Regards
Looking at the post by @mondialfan and reading the links he provided, I do not see any point in altering the values.I was thinking we might be able to improve on the cap in the zobel. any thoughts on that?
