I think I can say with some certainty there is something to be said for the Duelund resistors here
http://www.duelundaudio.com/downloads/Resistorsvol5no3HIFICriticHiRes.pdf
In this little comparison done by Martin Collom's a very well respected reviewer and he does say something about the negative temperature coefficient needing the same time constants to be of any use. Really everything can be effected by heat. I work in an electronics factory where many boards that I test have to be powered up for 10 minutes before tests can be run.
hotrody:
" I think sonics is the only solid reason to buy the graphite resistors."
I agree with this, its the only reason to buy!
hotroady:
"The graphite link has a muted reference to an early Duelund claim of a woofer circuit:
"to claim that any graphite resistor in front of this will "read" the voice coil and counteract fluctuations in impedance is obviously nonsense. I many cases the attenuation resistor(s) is/are not directly in front of the driver, rather in front of the crossover components, thus the crossover still sees a fluctuating impedance and we're nowhere. If we have a problem with over-heated voice coils, we should build bigger speakers.""
I don't know about all this, Nor do I really care whether the statement is perfectly stated. Its not a perfect world. As far as the negative effect, the degree of the negative temperature effect is of no real consequence to me. I purely bought the product to try out and it was so hugely successful that I nearly threw the North Creek Ohmites I was using in the garbage and these were their pick out of a 20 resistor line up for evaluation which BTW had the lowest temp coefficient which they were concern with some 10yrs ago.
I certainly don't need bigger speakers when my system can create a sound stage floor to ceiling and up to 30 feet wide siting 10 feet away with speakers 9ft apart.
Now the stock Forte's with my electronics is like watching a 8mm home movie with a small screen set up between the speakers.
Hotroady:
"OK, this assumes your ears can tell the difference, between the co-efficient and the sonic signature of the resistor. Nothing measurable, indeed attenuator resistors in parallel with tweeters do tend to smooth out the HF."
I think that the fact that Martin Collom's heard a large subjective difference validates my own experience. Yes Inductance can be measured as most drivers have inductance as do woofers and mids a voice coil is an inductor, it has DC resistance and Inductance so its ACR will always be higher than the DCR this of course varies from driver to driver but when your talking 10khz it can be significant. Again I have no real concern over the the temp coefficient claims. But just the sonics. I am concern with temperature when it can cause a part to drift significantly like carbon resistors, just measure one in circuit and remove it then solder one back in and typically they are often change a lot. I do like the sound of carbon resistors no doubt. And these have a positive temp coefficent. But these have a different application in an amplifier.
hotroady:
"The special feature of a graphite resistor, except for being non-inductive, is that it displays a negative temperature coefficient (a = -0.5*10^-3, (1/°C), thus when the voice coil heats up - and increase impedance - the graphite resistor will counteract this by lowering impedance. In practice this is most likely rubbish as the graphite resistor would have to act as an exact mirror of what is going on in the voice coil."
Again I'm not concern over this statement, as I said its not a perfect world. But the fact of graphite not having a positive temp coefficient means more voltage is over the voice coil or network plus the voice coil that is in a series network.
hotroady:
"Voice coils come in all forms with regard to former (alu, kapton, etc.), wire material, wire diameter and length, and to claim that any graphite resistor in front of this will "read" the voice coil and counteract fluctuations in impedance is obviously nonsense."
"Read" no! of course not. I don't beleive in everything, if I did I'd be a SS guy
my ears are more important.
"SET12:
" The Duelund enhances current flow is the way I like visualize it."
Yeah, but..that's not measuring, either! more facts/ less wank needed. Maybe it does/ maybe it doesn't.
So...if you put a Dueland graphite resistor shunt wound to a woofer, also...what is the crossover to do with all this extra current? Overheated voice coils certainly don't need it. It's still not going to respond to the woofer's voice coil impedance/ demands. As stated in the graphite resistor link
Yeah, I don't "stand with Duelund on this." Still could be one of the finest resistors made, though...I don't think the link detracted from it's sonics."
I don't need it proven to me one way or the other, the wank is working for me
You mean use a graphite resistor in shunt with a woofer?
You typically don't see this with woofers although a resistor can be used in a zobel network which is an RC series combo that is in parallel with a woofer and that resistor is going to see heat if the frequency is high enough as the cap starts to be seen like a short this will take some of the energy away from the woofer keeping its voice coil cooler but you can see resistors in parallel with networks of mids and tweeters as well. An ALK Forte network is an example of allthis, all the components have heat, some less some more. We use thermo cams at work to see when something is out of wack
In the case of the tweeter its dissipated by the Duelund resistor or what ever resistor is used for the Forte network. I was greatly surprised at the sonics when used shunting the tweeter.
I'm not about measurements in particular. I go after sonics I know very well a part with the same specs does not necessarily sound the same, it goes with amplifiers as well as anything else.
Yes I don't think the link detracted from the sonics either. He was concern over the statements he came across, I didn't see much on the Duelund site or Though at Parts Connextion I did see the statement "When the voice coil of a speaker heats up, it's impedance rises. The DUELUND Graphite Resistor counteracts this by means of a decreasing impedance."
There is no way of matching the two but if one doesn't rise then the other see's the voltage increase over itself, how much it any can certainly be debated. I just simply like the sonic's and I'm willing to pay what their asking for them.
Cheers
SET12
