Yes, there's a transformer under that spot and it will get warm.
I don't think it's a bias issue because both channels sound equally loud when I listen to sound in stereo and when I change the balance from left to right.The area pointed to is above the output transistor heatsink, but this runs almost all the way across the back - as the arrow only points to one side of it, this possibly indicates a bias issue with one channel.
I was just wondering if receivers especially older ones are suppose to get warm.
I asked this question cause I have panasonic home theater in a box receiver that gets warm sometimes.
The area I circled in this photo is where the warmth is. Like I said its not hot, its just warm.
If thats the case should I take the cover off, turn the unit on and wave my hand over the components for heat? Then if the caps are hot I should replace them.Those components which you have circled are capacitors. They do not shed heat as such (unless something is seriously awry, in which case get ready for a POP!)
As said on the other posts that the transformer is on the other side and that I'm a noob at this and I don't have any equipment I would have to take it into a shop.h3ll0, chances are that you have a bias issue here. Normally the transformer also gets a bit warmer and warmer (if not a bit HOT!).
Could you take some measurements?
