I'm starting to put together a list of parts to order from Mouser of replacement parts for my AU-9900. Everything is working fine, speaker relay was replaced by previous owner, but time to replace e-caps, trimmers, bad transistors, and other parts? There are a number of threads on this amp, but not a clear direction on a few items:
1. What line of replacement e-caps should I be getting? Nichicon, Elna, etc.? Specific line? I'd just like to hear what people's preferences are and briefly why.
2. There are many bipolar caps in there, and I assume the small value ones can be replaced with film caps? I have generally done Wima MKS2 series.
3. The Wima MKS2 series includes caps up to 10 µF last time a bought some. Can all e-caps in this unit with rating 10 µF and lower be replaced with the Wima films? I did that in my Eight, and seemed to work fine. Any reason not to?
4. Any suggestion for trimmers? Driver board appears to have 5 kΩ and 1 kΩ. I'm pretty sure the originals are adjusted from the top. (Also looking at getting replacement trimmers for a 5000X and a Seven.)
5. I've got plenty of KSA992FBU on hand. Assume those are ok with matched gain for replacement of 2SA798? That seems to be the recommendation. I've used the 992 in the past to replace 2SA726, same here where they are found?
6. Looks like a number of 2SC1313, and I've got lots of KSC1845FTA on hand. Assume these are ok?
Sorry I'm not listing these board by board in case those are not suitable in every location. I'm just trying to get as much on one Mouser order as possible rather than breaking things into multiple orders.
Will also be recapping the PS of my TU-9900. I've got a list for that, but would like to hear any suggestions for other things that might be needed with that tuner.
