Chuck awker
My amp stays on even when power turned off.Must be in the protection circuit, maybe.Red power light on always.
Any idea?
Any idea?
Just started doing this today.Had the amp for 7 or 8 years.Is this how it has always been since you had the amp or has it recently started happening? If it was like this when you got it maybe the switch was bypassed because it was faulty.
I just looked at the amp and the power light was on so I thought I left it on but no,it was still in the off position.Just started doing this today.Had the amp for 7 or 8 years.
I’d still want to be 100% sure the switch was the issue. I recently worked on an AU-717 international version (XX) that had a broken terminal strip on the rear panel by the cord inlet. Half of it had come free from the rear panel and was dangling by the connected wires. The loose wires could have have easily shorted to the chassis and caused a shock hazard.Using the on/off switch on power strip is essentially identical in function to using the switch on the amp. You don't have to do anything if that is acceptable to you.
Ok folks,I think I found the problem.BTW in case it is indeed the switch that’s broken, there’s a switch from an AU-719 on eBay at the moment. I’d bet it’s the same switch as the AU-717.
https://www.ebay.com/itm/295220094090
So when orv00 wad talking about continuity and such I was about to check it but instead I said to myself,what the heck,I'll just move it and see what happens.
Sure enough I just pressed it to move a little and what do you know....it works!!!!!!
Yeah,I think I will follow and check each connection to make sure there is no touching of wires and such then for the time being,secure it with a zip yie until I fix for good.Thats great much better than trying to find a replacement switch.
Please take out a screwdriver and investigate a little before you carry on using it. You could post some pictures of what you find, it should be quite simple to make it safe even if you have some broken plastic etc. Your safety is important to us.
