Trekkie4
Retired Member
Yes, I see here that your AT 440 has MicroLine stylusThank you, Trekkie (I'm one too!)…
That puts my mind at ease, a bit, regarding the VTA and arm height on the 120; the thing is, I AM planning on upgrading to an exotic styli on a cart like Audio Technica's 440...would the arm position STILL remain in that "below zero" stock position then?
This could be an issue, unless you work out the correct VTA for this kind of setup. Thing is, a standard conical stylus would be rounded, 0.6, 0.7mm in diameter. Even if it's elliptical, it is still going to be rounded 0.7mm in length, where the MicroLine stylus has irregular, or rather unusual shape. So remember, a sphere is a sphere (from any angle), therefore improper VTA on either ellipticals or conicals wouldn't be as audible and destructive on your records as ML stylus, due to tip design itself.
What I would personally do in your place is mount (and adjust) the cart, put on the new thicker mat you mentioned & then observe the tonearm position, to see if it's parallel to the record's surface or not. If the arm is still too high (leaning downwards), you will need to put some sort of spacer, or shim between the cartridge body & headshell itself. However, if the tonearm is now set too low, (leaning upwards), simply unlock the collar at the base of the tonearm & adjust it to necessary position, to the point where the arm is parallel.
