Audire Audio Components
Is it possible the preamp may need rebuilding?the mid/hi's are wonderful but bass doesn't seem to be there-
I've connected the amps to other pre's with tone controls and i can dial bass in.
thoughts?
Moebuster! Thanks so much for uploading the product brochures for these beautiful pieces of equipment!
So little is available.
The input sensitivity spec of 1.2V on the Parlando explains an apparent lack of volume on a specimen I bought some years back.
Hello AudioKarma Audire Thread Folks,
I've been hoarding Audire gear since my early college days in the mid 80's. Last count, 13 pieces. It is getting to the point where I need to have some of the gear worked on / troubleshooted / restored or upgraded. I have a very competent audio repair guy, but he has now mentioned multiple times that wiring diagrams / schematics would help keep the costs down. I am desperately searching for schematics for the Audire 2, Otez and Parlando amps. Any help out there would be most appreciated. I love the performance and obscurity of all of this gear and wish that Julius had positioned someone to take over his business, even just for parts & service. Regards, Drew Kohl in Flagstaff, AZPXL_20240114_215653460.jpgPXL_20240211_230645546.jpgPXL_20240221_191040108.jpg
thoughts?
Had my tech work his magic on the pre.bass restored.
I've been hoarding Audire gear since my early college days in the mid 80's. Last count, 13 pieces. It is getting to the point where I need to have some of the gear worked on / troubleshooted / restored or upgraded. I have a very competent audio repair guy, but he has now mentioned multiple times that wiring diagrams / schematics would help keep the costs down. I am desperately searching for schematics for the Audire 2, Otez and Parlando amps. Any help out there would be most appreciated. I love the performance and obscurity of all of this gear and wish that Julius had positioned someone to take over his business, even just for parts & service. Regards, Drew Kohl in Flagstaff, AZView attachment 3126179View attachment 3126180View attachment 3126181
Show off!!
your most welcome.
The diffet 1/1a is not an easy piece to work on, especially without schematics. It's a fairly advanced, fully DC coupled and FET input design that was ahead of it's time. As the brochure mentions, no trim pots were used to set balance or bias. The problem with using fixed resistors for this as Julius did, is that transistor specs can drift over time. Bias can possibly increase, overheating and killing transistors, similarly with the DC balance. I have seen repairs done by Julius where transistors were replaced and resistor values adjusted commensurately. Also, watch out because when any problems arise, DC can be sent straight to the outputs up to the rail voltage. This could kill fancy DC power amps or at least give you a hearty scare when the protection circuit of that amp desperately tries to track that assault. The circuit traces are delicate! This is not a piece to trust in the hands of an amateur tech.
It is worth it to keep them going though; It has an excellent transparent and airy quality with some signature JFET cream.
I concur with everything you've described, @rjb5191. My Andante is even more complex, being a true dual mono design, with mirror image boards mounted on a central aluminum chassis panel. There are no op amps - it's a completely discreet design, DC-coupled - with lots of super-matched dual JFETs. It does have offset voltage trimpots, which is a really good thing, because over time, several of the dual JFETs had drifted, causing very high DC that destroyed my brother's Otez when he owned the preamp. There are no trimpots for bias, unlike, for example, my Spectral using MOSFETs.
And yes, those circuit traces are delicate. Very easy to destroy or at least, lift off the substrate. It is also very easy to damage the JFET current sources, or the differential JFETs. There is no schematic available online that I was ever able to find. It took me months to get that thing working properly, and only after replacing several dual JFETs, a few resistors, and of course, replacing all of the electrolytic caps. Unfortunately, the modular Clarostat volume and tone controls are long unavailable, though there is a company that claims they have the parts to make the pots, at a cost of $250 each. I've drilled out the rivets, cleaned and lubricated the left channel pot, and have gotten a couple of years of use out of it, but I'll have to adapt a different pot in the near future, which won't be easy because it is board-mounted, with a long shaft extending through the chassis.
When my brother owned it, Julius had to repair and adjust it several times. Clearly, components were drifting even 25 years ago, and one failure resulted in Julius replacing one of the boards, which actually had a slightly different tone circuit component value selection. The last repair Julius performed was towards the end of his life, and the condition of the soldering showed he was having more difficulty with the work. My brother was one of Julius' first and most dedicated customers, and for whom Julius designed a special pair of his panel speakers, as I've previously described.
During my ownership, I've had to open it up twice to adjust offset. It's now waiting for me to replace the phono section dual JFETs, which are exhibiting the same signs of drift as the others in the circuit several years ago. Fortunately, I have enough to replace all of them, as well as other JFETs and BJTs, and even a spare transformer. It is clearly showing its age and temperamental nature of the circuit and components, but sounds incredible when working properly. The line stage is crisp and clear, the phono stage is very clean and articulate. I have yet to measure it with my more sensitive distortion analysis instruments, but it performed well with my test gear from the same era. When working properly, it's easily in the top 3 of our many good preamps.
Hello all,
Very early Audire / Julius fan. I have a collection of mostly disabled Audire pieces. Legatos, Forte, Noble, Cresendo, Diffets, Image 1, maybe 10+ pieces. A few prototypes, sub, preamps. Id like to find a repair person for a Noble set. or even a Forte. Most I just need to let go. Anyone interested? Ill get some photos. Been my systems for a long time. Very happy to hear from any Audire fan. You sound like you knew Julius. I knew him since I was about 10 yo. Im old now.
Hello all,
Welcome Audire 2!
I know of no one specializing in Audire repair.
I for one, would be interested in any remnants of your collection there.
I have a couple Audire pieces, but wouldn't mind having others.
Not sure my reply made it. I would like to repair Nobles, and Forte. The rest i should 20250112_175408.jpglet go. Ill get a list, pics, and see. Im in fort bragg, ca.
Hello all. Old Audure fan. I have several pieces , Legatos, Diffet, Forte, Crescendo, Model 1, Noble set, Image 1, sub, prototypes, Mostly needing work. I like to repair a couple, and let the rest go. Ill get a full list and pics.20250112_175408.jpg
