Okay, I have two issues and I need some input before I just jump in and replace parts....
The first issue I have is when shutting down the 1080. Upon flipping the switch, the lights go out, then the FM indicator light lights up and goes out along with the click of the relay. The unit powers up fine and I have recapped and done a number of transistors, resistors and such a few years back and set the offset, etc. I never noticed it before, but I'm sure the FM light isn't supposed to flash when the relay clicks on powering down.
Second is the volume. I've clean it with Deoxit and followed up with fader lube, but in order to get the left channel to play, I have to bring it up 3 notches before it kicks in. All the while the right is playing from the first notch. Once it is there, I can bring it down and it still plays. If I bring it all the way down, I have to bring it up a few to get it to kick back in. DC offset and bias are set to service manual values. So I'm not sure if it is the volume pot or somewhere in the chain.
The protection board is the only board I haven't touched. I was meaning to years ago, but didn't have replacement relays and started researching if I needed to replace them and one thing lead to another and I never got around to it. I will be doing the board, but need to know if the relays are a must.
Thanks
Thanks
