boeingpilot
I was asked to take a look at a Bell Sound 2418 integrated amp to see what it would take to get it back into service.
A little background -- over the past 30 years I've taken care of the care and feeding of a Dynaco ST70 and PAS3X. Also brought 2 other ST70's and PAS's and a SCA35 back, but in each of those cases went straight to recapping the power supplies before I would even think of powering them up.
In this case, as the owner wanted to know if it was even close to working, I took the following steps
-- checked all tubes on my Jackson tester. All tested at 100% or better (geez, 4x west german telefunken 12AX7s!)
-- Physically inspected the unit for obvious damage (none)
-- Powered up slowly with Variac. Passed the no smoke test.
-- Introduced signal, and found that it worked (at 90V) the only noticeable noise was a dirty volume pot. Took care of that with DeOx. No noticeable 60 hz hum
-- Brought the unit up to 110V (which would've been US line voltage back in 1961 when this was new)
Sounds very nice connected to a pair of Heresy I's. However, started to get an issue... Found that when bringing volume above say between 1/2 and 3/4 range, I get rapid motorboating both channels. Problem is worse when increasing bass.
So -- I'm thinking the power supply is starting to breakdown under high load? I'm ok with dropping the $80 or so on new filter caps, but want to get a reality check on where else to look?
Ideas? Advice? Seems like it's a nice little amp (perfect for use with efficient speakers like the Klipschs)
