Also, any other feedback from any of you about specific brands/types of polypropylene film caps to use here. As much as folks complain about the general industrial nature of Panasonic electrolytic caps compared to high-end electrolytics from Rubycon, Nichicon, Elna, etc, too much focus in audio circles revolves around electrolytics in general, as designers know where to use film-caps and stay away from electrolytics in the audio-streams of their circuits. That said, i've had good results w Panasonic polypropylene film caps in audio circuits like speaker crossovers, but never really done any real comparison of all the polypropylene film caps on the market, and all still depends on finding ALL the values you need for that complete circuit. I'm open to polypropylene film cap suggestions while this thread lingers.
This topic is near and dear to my heart and sounds like a very exciting and worthy experiment to conduct. There is definite potential to hear audible differences between all 4 versions. I've recapped or upgraded 40+ receivers/cd players/crossovers/turntables and here are my observations. Unfortunately, I have no scientific data to back any of it up. It's all just listening passion for me, so you'll have to take what I say with a grain of salt. However, after listening very closely to their "before" and "after" versions, there are some outcomes that keep occurring.
Polypropylene: Can make it sound brighter, a tad colder with more articulation with the added potential to create more of a perceived "digititis" or more of a metalized sound (similar to, but not as bad as single layer ceramics) depending on the cap (metalized vs. non-metalized and quality and materials inside the poly). Usually the effect is that it has better definition and makes a "hi-fi" sound with more focus and detail on the treble afterwards.
Electrolytics and high-end $ polypropylenes are typically what people talk about when it come to caps. As you probably know, there's a whole market of these boutique caps, some of which can be very good and cost a lot of money. I'd say this is what people are most familiar with on these threads when it comes to cap discussion. There are other cap considerations too however, that are equally important in attaining 'the sound' besides just these two capacitor types/applications.
My experience is that spending more money on audio-grade electrolytic caps is always worth it and offers a better outcome than going in and making a parts list based on superior specs alone when shopping. For a very long time I spent A LOT of time gathering an impressive stock of electro's with the best specs, thinking it would improve or clean-up the sound. Rubbish.
What I found is that the "audio-grade" caps with their measly 1,000 hour lifetime rating always sounded better in almost all locations. They're a little more natural than the bright sterility of caps with the lowest impedance and ESR, highest lifetime and ripple currents. I don't mess with Blackgates or Teflons. Too expensive and/or hard to find, but you may consider it here if you have the resources for experimentation. But, they are just not practical when there are so many other cheaper, more available options to consider.
Mylar: Better than a SLCC for "rounding out" the sound and can be had for cheap. Sounds veiled but you won't know that until you compare it to a polycarbonate, polystyrene or polypropylene and hear how much more "open" the sound becomes.
Single Layer Ceramic SLCC: Bright, gritty, grainy BUT has some hi-fi glitz to it on the upper frequencies. I replace ALL SLCC's with the more stable multi-layer ceramic COG/NP0 MLCC's whenever I come across them. In every instance, the sound is better, more even-tempered and MUCH easier on the ears. MLCC's are a lot more expensive but still relatively cheap and always worth it in my opinion. Diclaimer: I have never recapped a tuner. I wouldn't mess with replacing SLCC's in them unless they were found to be out of spec and would just replace with another SLCC.
Polyester: Ok, definitely not bright and a good choice for more natural non-fatiguing easy going sound. Can sound just sort of middle-of-the road. I found there is a lot of variation on the sound of all the assorted film types and materials and this is where you can spend some time experimenting with different flavors and materials as they are relatively cheap. PET, PPS, Polyester (metalized, stacked, etc)
Tantalums & Teflons: Haven't tried them but Teflons are said to be the best sounding capacitor available.
Silver Mica: Very stable, transparent, open sounding caps and only available in the very small pF-nF range (along with most everything else listed here) besides the electros. Consider COG/NP0 MLCC's to replace SLCC's
Polystyrene: Very similar to polycarbonate. A Huge improvement in sound over well..most everything, especially SLCCs, Mylar, Electrolytic, Polyester film types. The veil is lifted, clear and open, natural, non-digital sounding.
Polycarbonate: Similar to Polystyrene but a little more "rounded" sounding. Very very good capacitor and I recommend using them in matched pairs along with matched pairs of styrene's in other key coupling locations when possible.
Couple other things. Whenever you're working on an obviously mirrored, symmetrical L/R circuit layout it gives you the opportunity of leaving one channel stock, and replacing the cap in question on just one side. Then, do listening comparisons in real-time and then only replace both channels using the better sounding part(s). Do this practice as much as you can instead of just blindly soldering everything in place and just listening to it once after it has been re-assembled completely.
This will prevent you from installing any new parts that actually sound worse than the original which will eventually happen if you're not careful and listen throughout the entire process.
Obviously, this is not always possible given circuit design variation, but is the best way to upgrade (if possible) as it guarantees the resulting sound you're after. I just finished an EAR834P phono pre-amp clone and Proton D540 Integrated Amp upgrade. There were cap locations where I went through 4 different types/ cap materials before I settled on what was clearly the superior choice for fidelity. In this way, every cap, every change made was the best option I had available.
Of course, it helps to have a large supply or library of different caps on hand with the same ratings. And then on top of that, some electros (for instance) do need to be on for several hours before sounding their best. The upgrade process I describe works best with films because their final, resulting sound doesn't change much over time. Even though electros are typically rated at a 20% tolerance, most new, quality caps will measure out at <5% of each other and can, and therefore should, be matched up in pairs of within, say, <3% tolerance or less.
Here is what I recommend for electrolytics after several hundred hours of careful listening. Keep in mind circuits are different and the same cap can sound different in another circuit. I recommend keeping capacitance the same but experiment with higher voltage replacements for more perceived headroom and 'ease' with less audible distortion at increased, higher volumes.
This is how I choose the right audio cap. First choose the one with the right sound signature, then increase its performance characteristic by raising its voltage which also has the added benefit of lowering its ESR and raising the ripple INSTEAD of buying initially buying another series of electrolytic with better specs at the oem voltage rating.
1,000 hour lifetime rating scares some away from using these "audio-grade application" electros, but, just use them anyway. Most original caps are typically 85 degree rated 1,000 hour caps that can still sound pretty good, many of which are now decades old.
There are others I haven't tried Including Nichicon: KT, KA, UKA, UKT. Report back with any findings on these. I will say I do not like UKW, UFW, UFG, FG, or those pretty green Muse ES bi-polars when compared to better options.
Elna Silmic II (RFS): Very good smoothing and warmish all-around "natural" cap with its silk fibers that should be used as much as possible for sizes large and small. They're bigger than almost all originals, so measure for fitment prior to ordering. Plus, as an added benefit, (in my experience) bigger caps generally sound better compared to a physically smaller cap of the same rating.
Elna Tonerex (ROB): I think I possibly like these even more than Silmic but they're only available in a few, limited sizes. Highly recommended to find a place to add a symmetrical L/R channel matching pair or two of these. These caps can sound dull or muddy at first but once burned-in, sound just as good as Silmic in my opinion. It is not possible to do a complete recap with these because they're only available in limited values.
Nichicon LKS, LKG (Gold Tune, Super Through) caps for power supply. I use to use high-end Chemi-Cons for power supplies with their superior ratings in lifetime, ESR and ripple, but they do NOT sound as good even though they're technically "better".
For polyester films, I like the vintage Mullard tropical fish and ERO line which has now merged with Vishay. Their MKT1822, MKT1813, MKT1817 et al. line can be pretty good, but MKP may sound better depending on location. Old Siemens or other vintage German film caps always sound pretty good.
Evox Rifa CMK for cheap, available polycarbonates and usually Mial or TRW polystyrenes seem to be what's available. Larger value, high quality vintage Russian military capacitors can also be found online for cheap.
Good luck with this grand experiment, I look forward to your findings. Jess
