Thank you TPK. It's very encouraging to hear other people been positive about loss hearing and tinnitus. Even when I mainly remain positive, still have my ups and downs... Deep downs regarding this, especially when listening is such important part of my life.Those are truly beautiful. You did a super job, down to the finish. I wish I had a pair made from that wood.
Tinnitus is not a hearing ending condition from what I read, and it does subside. Just protect your hearing religiously going forward
One thing is the electrical setting of the crossover, in this case is set at 787hz for the low pass, and other is the acustical result (this depends a lot of each driver características). To make this drivers crossing nicely at 1.32Khz, one should use this 787hz low pass. I was playing a lot, and this frecuency was the one given my the flattest response acusticly at crossing frecuency 1.32Khz. I take all this nice information from Zilch development of the Z19 crossover, the one he design for the Altec Model 19 wich uses the same drivers I am using.So your running the woofer up to 1.32 kHZ, then from there the mid horn comes in , (you mentioned 787 hz, which represents what?).
DID you try any other Low Shelf settings besides the -6db x 5.08kHZ?
Beautiful work by the way.
Yes this is something I plan to do in the future, so far I am enjoying the sound is coming out from this diaphragm. As I am new to Altec horns, well, I stil don't know what I am missing.I’m not sure of the availability of them in Colombia, but I would ditch those “generic” diaphragms and get some GPA or Radian diaphragms. All the aftermarket Altec diaphragms I’ve used (with the exception of Radian) suck.
Yes you are right, that was one of my biggest concerns, specially because my other speakers, Canton CT-90, sound amazing from 20Hz. But we'll, this Altec certainly do not go that deep in the bass, as I recall from my measures they can reach to 35Hz, but that is more than enough to fill my living room, and the way they feel the room, they are very transparent (I mean they easily disappear) That makes Jazz and acoustic music to sound beautifully. So I am happy with the bass. For electronic music, yes, I miss the deep bass a bit but not too much, because any way this driver/cabinet sounds very well, I would say from 50Hz and up.As I recall (I'm too lazy to go back to the thread early posts), you were concerned about the bass output of the 416-8C. So how is it in your custom cabinets?
Here is my solution to model 19 cabinets.Hello friends,
A year ago my Altec Journey, started with the acquisition of a non-matching pair of possible 802B-802C (Still for identification, I might create a thread for this) compression drivers. I just bought them because I realize they were of value but with no idea of what to do with them in the future. But two weeks ago, everything started to move at a huge speed! I found here in my city a pair of 515B (for re-cone. I might create another thread to ask about this work too) and a pair of 416-8C with the original cone and in general good condition. Last week things become even better, I found a set of three 511B horns including 902-8T compression drivers. Well, maybe you can imagine my happiness because I got the feeling that this would be something... and all this for a very, very cheap price; to give you an idea, around $80 USD per horn+driver set.
I have been reading a lot, trying to figure out what to assemble with the 416-8C and 511B, 902-8T combo. I found that this make almost a late production Model 19, but I have been disappointed for all the bad comments on this variant of the 416 and the non-matching horn (Model 19 using the 811 horn).
Knowing this 416 is not the best performer, I would like to hear your ideas about what could be the best cabinet for this variant of the 416-8C. What cabinet could make the most of this woofer?
I have though about an Onken cabinet, but read from someone here that there is not a big difference when using a regular bass reflex cabinet. And for me this has a lot of sense, if Onken cabinets were such a good thing, for sure the big brands, let's say current JBL, would be using this type of cabinets?
My other idea was to build a model 19 cabinet, but again, the model 19 cabinet was designed based on the 416-8B, and adding the complaints about the Model 19 using the 416-8C, well, seams not the best option.
So far my best option is to build a 620 cabinet (and set the horn on top), at least in the "Customizing Altec Enclosures" paper there are specs and measures to adapt this cabinet specifically to the 416-8C, and as I am not a speaker designer and my experiences with box design is little (even when I have been reading a lot about this too), this is possible the best to do.
What do you think guys? Am I right thinking that my the best option is to build a 620 cabinet? Or to design a new bass reflex enclosure could get more out of this woofer. Any help to solve this confusion will be great, guys. One more question, it is this the 416-8C really that bad? Does anyone have make measures comparing this with the 416-8B?
Cheers,
Rodolfo
A long time without checking over here.. beautiful solution. I have the feeling your boxes are bigger than Model 19. Did you keep the same internal volume?Here is my solution to model 19 cabinets.
Build cabinets that are pleasing to you.
Something with the volume and venting.
I have always thought the 19's cabinet was ugly beyond words.
So I built my own, they are fantastic.
