I’ve been installing audio/video systems for a living for the past 22 years both in residential and commercial settings so this is what I recommend. Place the speakers on the 14’ wall and 10’ apart from one another. You will have to experiment with the distance between the wall and the speakers to get the best imaging and bass response. You usually don’t have to bring them out further than 2’. Having two subwoofers vs one is a good thing so you’ve got that covered. Place a subwoofer in each FRONT corner. People might argue that subbass is omnidirectional and that is true but if you place a subwoofer right next to you or behind you I guarantee you’ll know it’s there when you hear an explosion.When you go to a movie theater the subs are never anywhere other than in front of you. Same thing at a live performance. A subwoofer should “disappear” into the system. When properly set up all the bass should sound like it’s coming only from the front speakers. Your listening position should form an imaginary equidistant triangle. So if your front speakers are 10’ apart then you should be 10’ away from each speaker. Toe in your front speakers to where they are facing you. Tweeters should be at ear level when you are sitting. That should place you back away from the wall roughly 12’ which is good. You don’t want your listening position to be right smack in the middle of the 30’ depth of the room because you will get bass cancellations there. In my opinion the rear surrounds don’t have to match the fronts. But all the tears should match each other. Given you have 7’ ceilings, place each rear surround soeaker 5’-6’ high on each side of the room and about 1’-2’ behind your listening spot. Do not aim them at your ears. Just straight forward at each other.They are surround speakers so they should only create ambiance. Aiming them directly at your ears makes them directional. Ideally your center channel should match your front speakers in timbre and that is why it’s usually a good idea to use all the same brand that matches the front speakers. Try setting up your receiver using a “phantom center to see if the sound improves. Center channels are great but work best when they match the front speaker’s sound. Equalization may help if your center doesn’t match your fronts but usually not cost effective vs just matching all three speakers. Also the center channel should be placed either directly above or below your tv. Below usually works best because a lot of times a tv is mounted up high and placing the center on top gives you a roller coaster effect with the sound. Aim the center directly at you. Ideally all the speakers in a surround sound set up would all be the same distance from your head but rarely is this possible usually not practical. Receivers can compensate for the different time arrivals but the closer you can physically accomplish this the better. Hope all this helps. Good luck.
first off - thank you for taking the time to write this. I found it extremely helpful.
interestingly, before you wrote this i was starting to track to what you suggested.
i played around with mains closer to center channel and subs on the outside and the reverse... mains outside of subs so further away from center.
the problem i was having was the center channel seemed to dominate... i tried to correct by increasing level calibration of mains/lowering center... but center channel was still dominate...
I starting to hone in on it by putting in stereo... so center channel was not active... but it still sounded like the center channel was on and dominating... the placement of the mains was creating a center channel image!
when i moved mains to outside of subs, they happened to be 10 ft apart!!... then i adjusted down the level calibration of the mains and achieved great balance and separation. The “center channel” no longer dominated. I’m quoting center channel because of how the mains were creating a center channel sound before which was then amplified when the center channel was in action. Crazy.
i’m very impressed with how spot on you were with what actually works! Appreciate the information and expertise share.
Next challenge is subwoofer being great for music but during movie action scenes, it seems lower frequencies are just too much... bass becomes dominate and the room shakes... i love bass but this is a distraction.
thinking i’ve got a case of room gain maybe...??
I’ve read you can double longest room dimension and that is waive length of where room gain begins... and my room is actually 23x13 ft... measured just now... 40ft waive length is 28hz so using that data point as proxy... impact is 5-10 dbs per octave below starting point. Octave is 2x exponential i think so expect i’m getting + 5-10 dB around 15 hz causing my issues... my current theory at least.
i’m limited to how i can address this...
1) avr equalizer - settings at 63 hz, 40 and 25... max adj is -6 dB. Going to try taking 25 hz to -6 and 40hz to -3 and see how i do.
2) thx sub settings include bgc - which is boundary gain compensation. I think that basically does something along the lines of the adjustment above. Manual says its to compensate for excessive low frequencies when listener is near a room boundary. Played with this briefly and did not love it... seemed go tame the bass too much.
3) perhaps a more extreme option... but i guess i could play with plugging subwoofer ports... theory there is it would cause them to start rolling off higher up in frequency... but thinking this will be a last resort if other fixes dont address.
so - plan to play with this and see how i do... welcome thoughts and ideas.
Re-centering myself on point of this thread as free or very low cost improvements. So far i’ve made significant progress... moving mains further from center and adjusting speaker level calibration was another major and free win... its amazing how much small tweaks like this matter... and how difficult it is to get right and know what to tweak...
