Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Where do you guys recomend I get the foam needed to refoam my spreakers. I need to to refoam the following: Minimus 77 (5inch woofers), Cerwin Vega D-3 (10 inch Red Foam), and EPI 105 (8 inch). Any suggestions
Only place I could find that had the CV dustcaps (in all sizes) to go with the 12" & 15" CV kits. Ended up they were nicer kits than the ones I got at Parts Express before
I use the foams from MAT Electronics. You should know that sometimes you have to get creative to make them fit some applications as they are pretty generic in sizes. I have used then successfully on all of my refoaming projects though. They are a pain with cones that have the flat mounting surface.
