Cannot read the print on it, which one is this??
Kenwood lo7 c1Cannot read the print on it, which one is this??
Hi ! could please elaborate what you mean for transparent ? low noise and low distortion ? does the opinion apply to both the phono and the line stage ? thanks a lot, ginoMarantz 3650. Not because I own one, but of the preamps I've heard that passed my work bench the 3650 is very transparent.
I love these Sony's. Thats a very good one. Definatly one of the best rated reviewed preamplifiers then and now and still very reliable!.Aloha
today picked up a Sony TA-2000F from Customs Office
unfortunately there is no Signal ,power on lamps ok but no Sound out the Speakers to bad it's a case for Heinz the trusted Technician
Big surprise when take off the hood
found a jumper for the required Voltage that's gorgeous
Cheers
Outside
and inside very good
Hi ! sorry to bother you. As the E30 has a remote controlled variable output ....... Topping E30 ...
Wow great pre amp.Sony TAE-8450 nice to have fits gorgeous not only with Sony poweramps
Cheers and stay safe
No I haven’t, and I have no desire to do so. The Parasound preamp controls all my digital AND analog sources as opposed to the E30 which would only control my 2 digital sources.Hi ! sorry to bother you. As the E30 has a remote controlled variable output ...
So it can work as a line preamp with only digital inputs ...
i wonder if you have tried it connected directly to the Parasound power amp. It is said to be very transparent even if the volume is digitally controlled.
And moreover ... which psu are you using for the E30 ?
Thanks a lot, gino
Thanks ! yes you are right ... the E30 is mainly a dac ... regards. ginoNo I haven’t, and I have no desire to do so. The Parasound preampcontrols all my digital AND analog sources as opposed to the E30 which would only control my 2 digital sources.
The power supply that I use for the Topping E30 is from an old Roku streamer. 5 volts, 2.5 amp.
ProBlogger,Parasound P/LD 1100. Bought it new in 1996...still going strong. Topping E30 is running through the direct input, feeding the Audiolab 6000CDT CD transport. It doesn’t have a phono section, but I don’t need one. Dual mono and class A, designed by John Curl.
Audio Research made some nice stuff, but it can be a bit sterile sounding.
I'm a David Hafler fan, the Hafler D-110.
Just picked up a DH-101, what did you do to "update"? And who did it? I'm also in the Twin Cities.My updated dh-101 is one of my better preamps
