I know for a fact that if the accelerometers fail in a control driver(Delta/Gamma/Beta or even IRS-IRSV)you are in trouble as there is no off the shelf accelerometers that are compatable with the servo controller.If your put in this predicimant the Gamma's are only as good as a Delta will ever be.A Beta is totally worthless as it doesn't have a passive crossover to fall back on neither does the IRS or IRSV.
I have gone to extrodinary lengths devising an accelerometer to work with the servo controller just to have spares.Let me tell you that it was costly and timely,not so much in the parts department but research and experimentation,but they work perfectly and I must add that the accelerometers even have a better response than the original.As they get old the accelerometers fade away and response and accuracy let you down resulting in a slower response output of the driver,sounds more like multiple subs.This is because the response time cant correct the motion of the driver or phase switch of the signal quick enough resulting in a floppy bass.
There are plenty of servo woofers available if you know where to look.
If you can easily find the speakers with the lights out, something isn't right.
No one in their right mind would do that trade.Perhaps a basket case set of Betas, however by the time you got them up you'd spend more than you would for a pair that was 100%. Beta servo box/crossover alone is a $1600 item fully functional.
Paul
....As they get old the accelerometers fade away and response and accuracy let you down resulting in a slower response output of the driver,sounds more like multiple subs.This is because the response time cant correct the motion of the driver or phase switch of the signal quick enough resulting in a floppy bass.:thmbsp:
There are also many capable active crossovers available that can and will work wonderfully with Beta woofers.
I would agree that the RSIIb look the goods and they will sound sweeter or smoother in the mid frequency but the Kappa 9's just grunt along with a complete sound spectrum covering all frequencies,where the RSIIb will lack some what in the mid bass where compensations would have to be made with external eq's comprimising the signal path niot mentioning taking away quality sound.You simply cant take a driver out of its comfort zone to cover a frequency you dont have to begin with.Doing this just compremises the speaker and takes away its natural frequency range it was designed to represent.For example crossing the bass at a higher frequency will take away bass not to mention take it out of tune with the enclosure volume and on the other end taking a mid down to the upper bass frequencies just makes it sound not as silky and smooth not to mention the imaging you lose.Mid bass is so important,just look at the Delta/Gamma,its L-Emim has the same surface area as a 12" driver.
Flick the switch to extended bass on the Kappa 9's and I say no more.Of course you need the amp power behind these speakers to do this.This is in stock formation that I am talking about.
Now we will talk about a set of kappa 9's that have been hotted up.High quality caps,self wound inductors and specific speaker cable to match certain
frequencies.Basically an all out assault.No eq's or active crossovers.I bet you wouldn't would put you speakers on the table in a comparison test because you will no longer own them.I'm not being mean or rude just speaking the facts.
Of course there is better speakers in the Infinity family but the Kappa 9's are not to be wreckened with.Delta/Gamma and of course the Beta take it to a complete new playing field so I think comparing the RSIIb to a set of Kappa 9's,Delta/Gamma or Beta is a complete over statement.I would compare them closer to a hotted up pair of Kappa 8's from personal experience.
By saying this I dont mean that Kappa 9's are the holy grail,but when comparing prices they certainly do a damn good job.My Delta/Gamma sound better in Delta mode but only in the upper frequency.The upper's sound silkier and smoother (basically more correct).In Gamma mode they walk all over the Kappa 9's by far.Comparisons I have done come from personal experience using the same amplification,cables and source material,and all comparisons in the same room.I dont mean to offend anyone but I stand my ground.Comparisons based on the complete Kappa family and the Delta/Gamma.
The last pair of Kappa 9's I saw in Australia were selling for $3,500. I paid $2000 for my RS4.5's and have not regretted it. Also a swept sinewave test on the bass section of my speakers shows a 2 db drop at around 70Hz caused by the complex crossover. This would contribute to the suckout phenomena.
Also there will always be a discontinuity between a dynamic bottom end and a dipole midrange/bass no matter what dipole speaker you are dealing with. Anyone with Martin Logans with a dynamic bottom end will tell you this. Even the IRS-V had issues when it was reviewed in Stereophile or Absolute sound, but if you are willing to live with this then I think the benefits outweigh the limitations and is why people are attracted to this type of speaker design.
Also the RS-1B and RS-2B will have these issues as well but Stereophile said that the RS-2B's were a very underrated speaker when it reviewed the RS-1B many years ago
regards
I think a lot has to do with the way the speaker and room work together. You can't expect an IRS to work well in a tiny or even average size room, it was intended for big spaces. And most of these big Infinities require a lot of careful system matching, possible biamping, and room treatment. A good room always helps.
So ranking the speakers is kind of a relative thing; the answer is always contingent on a lot of things including, as has been pointed out, people's preference in sound and music.
I would never pay that much for a pair of Kappa 9's. But I would like a pair of RS4.5's but they still cost to much as I can buy pairs of RS-1b's for less than what you pay for 4.5's. They just didn't make many of the 4.5's and I can't seem to find a pair yet that is complete with controller and in good shape for a reasonable price.
I also find the bass end of the 4.5 to be down at 70 Hz although I had a broader (and slightly deeper) dip that extended up higher. Most folks assume there is a problem with the lower mids of the 4.5 but I think the hole is in the bass system. The broadness of the suckout in my situation may also be due to my using a 24 dB/octave Linkwitz-Riley external crossover rather than the 6 dB/octave crossover recommended by Infinity. The 70 Hz hole remains with either. Room effects also cloud the issue a bit.
I can crossover the EMIM and woofer at frequencies up to 440 Hz using any slope and the bass suckout remains.
Rabbit, have you tried EQ at 70Hz to correct the dip?
You'd best bypass the low frequency crossover and drive the woofers directly with some eq.
regards
