soundmotor
super modified
That is a good looking speaker/room interface ya got there
Damn straight, that's freakin' sweet! (Tends to confirm why I like the L1230 over any other speaker ADS made from that era too.) It is also good to see the high-Q peak gone which is likely active crossover interaction. OP, you might want to try your biamp set-up again with these changes -
No auto-correction EQ or any boost, just HP function only
Lower HP point (adjust between 300-400Hz), whichever gives the best result
Measure
Reverse polarity of amp/speaker leads driving MF/HF section on the L1230's
Measure again
You'll need to fiddle with crossover point & phase coupled with listening at low/moderate level and measurement to dial them in. The above doesn't seem like much but it is a good couple hours on a weekend afternoon. You should end up with something very close to your 'no EQ' RTA image above. Then you can manually adjust the bass level to where it sounds and/or measures best. This is where I would be the most interested in your comments as to how the system sounds so configured.
The only other improvement that you could do to the L1230's is to provide a steep HP to the woofers themselves and add a subwoofer if the low bass drop-off is too much. Your room is helping you (or as much as the RTA can be believed) so you might not even notice that you have HP on the woofers. I would probably try various HP points from 40-65Hz if you ever get any woofer bottoming. This would be totally dependent upon how you listen to them though. If you run them hard on dynamic material such as orchestral or use them for home theater, it could prevent mechanical issues and potential woofer failure. This is the one weak spot on the L1230's.
