This is correct.
The chief advantage of using the C2000 is it has crossover points and contouring picked specifically by ADS' design team for the L1230 and L1530 models. It can be modified to use with the L1290/L1590 as well but you lose some of the specificity in the process. Same for use with other speakers; it can be programmed for that but you aren't getting the custom-tailored application as you do with the L1230/L1530.
John
John
I'm pretty sure you need an active crossover to bi-amp these speakers as well. The switch on the back removes the woofers from the internal xover network, while the 4000Hz crossover point between the mids and highs remains internal to the speakers.
