Yeah, 80 watts a side should do the trick, knobs notwithstanding.Whew. I'm stuck now. I have a Sansui 890 that seems powerful. It's got a million knobs.
I could use that I'd think. ???
Fives have 12 inch woofers
I'm just calling them what KLH called them, which was 12" but who's counting, they're really about 11"Actually, the woofers are 10"
Not sure why they didn't just use 12's, other then a cost measure?
My Model 5's are currently at the refinishers, so I can't put a tape measure to them, but I suspect the 10in measurement comes from the original KLH woofers, which had no metal basket and were directly mounted to the baffle with epoxy. The only way to measure those drivers is via the diameter of the surround+cone.
And they do indeed measure 10 inches that way.
However, if you apply that method of measurement to other speakers you'll find, for example, that the "12 inch" woofers in JBL 4311's measure 10 5/8".
If you're wondering, I did just check.
Measuring from outside the metal surrounding of the woofer, the Five is about 10 3/4". The 3a is 12.
I just found some info on that online. At 20 wpc, that is pretty low for Fives. KLH recommended 25 wpc minimum on their ads back in the day.
Others will weigh in on all of this so stay tuned.
Fives are really the pinnacle of the KLH line.
That's interesting.
The epoxied-in KLH woofer is a bit larger?
If it had the 3/4 inch mounting flange of the JBL it would measure 11 1/2".
I thought the only glued-in/frameless woofer in the KLH line was the early version of the Six?
