biggest power amps I have EVER seen
Wow those are huge! I cant imagine how heavy they are, you would have to have a one hell of an amp rack to hold those.
I don't see how you could really go wrong here, if you can get them back in working order. 2 huge transformers/4 filter caps for a mono amp?! That's a sh*tload of output transistors if you have to replace them in one of those amps though! Really, who doesn't need 1120W monoblocks? :D
FWIW, these amps were never intended for audio applications, however most of these are/were custom spec'd for their intended applications which cover a broad range. I've seen them used in MRI and other imaging systems. I think these can also be configured to strap multiple units together for increased output power.
The seller is off a bit on the weight as well, they're closer to 100 lbs each.
http://cgi.ebay.com/3-7570-Crown-Te...953?pt=LH_DefaultDomain_0&hash=item255f0662b1
Not mine, no affil...
but, holy freak these things look like miniature power grids!!!!
And they are mono amps!!! Only one works but good god I can only imagine what a refurbed pair could do!!
Then you haven't seen the Crown MA-10000. But, before you seek out a MA-10000, be advised you'll need 208V three-phase power to run it. :yes:
http://www.crownaudio.com/pdf/legacy/k10684.pdf
And what would the application for that be?
Containing plasma in a nuclear reactor.:yes:
Also, the fields in an electromagnetic resonance imaging system can require vast amounts of clean highly regulated power,
EDIT: in reading about the amplifiers posted in the OP, it's also mentioned that they're used to drive SONAR aboard ships, and as well can serve as a precision benchtop AC/DC power supply.
Big, but not huge, and likely not audiophile quality. Check out some of the amps fom Krell, NRG, and Audio Research.
Huge monoblocks are cool. :yes:
I was hoping to win these mondo tube amps but at the last hour they jumped up a bit...
Way too cool! I think I have a couple of old equipment bases from my defunct business that look similar. :scratch2:
I wonder if Mrs. Scuzzer would let me put something like that in the living room?
I bet you'll they'll sound just as good as the JBL Synthesis ones. I've not been real impressed by a number of "audiophile" amps TBH.
I'll personally take a big-ass convection-cooled pro amp over a Pass Labs for instance. While there's a reason you often see stuff like halcro in mastering facilities, bang for buck has always been with the pro audio amps any day of the week.
Pro amps aren't necessarily bad. But a premium is placed on their ability to:
1. be bounced around a lot and still perform (in trucks, on stage, etc.),
2. Be run at, and beyond, their limits for hours on end without FAILURE (when on tour). They'll take a less than perfect sound so long as they have continuous sound for as long as the concert tour (and of course each concert) lasts, and
3. Be cost efficient on a per-watt basis, because on tour everything relates the the power (think "11" in Spinal Tap).
In contrast, audiophile amps can be a bit more fragile in the physical handling department (because they aren't taken out on tour), and shut down easier in "protection" modes when pushed too hard. But supposedly the goal is sonic purity.
That doesn't mean that every audiophile amp reaches that goal, or every pro amp ignores the sonics. In fact, you see quite a lot of overlap by the best companies, who often compete in both arenas.
Studio personnel go with what they know, and most work up the ranks as roadies or performers. So they go with pro names and pro lines, even in studios.
I have a 140 Lb McIntosh amp (500 WPC or 1,000 Watts in mono mode, for any load from 0.5 ohm to 16 ohms) that I'll put up against those Crowns, both in size and performance. Its actually quite rugged, but you won't find it competing against many "pro" amps because of its cost. The Dead toured with McIntosh amps, but that was only because of a large, psychedelic-inspired donation to their equipment fund.
Bingo. Pound for pound, it's really close to impossible for "hifi" to compete with pro audio for amps (and often speakers/DACs/interfaces and generally almost everything else as well - case in point with another thread with the Behringer B2030Ps...) There's just not nearly as large a market for nice powerful boutique 2-channel amps of the hifi variety as there is for clean and gutsy dj/PA and monitoring 2-channel amps (ditto most other types of playback components).
