Really? I can only find electrical specs.
For most audio applications the 3.3volt input sensitivity would NOT be compatible.
Notice also that no specs are given for damping, generally an important spec to advertise in the audio world.
Spec sheet for the amplifiers in the OP:
http://www.aetechron.com/pdf/7560.pdf
Umm, althought the damping factor is not present, if we use a general DF calculation of DF = load impedence/output impedence, the damping factor for the stereo connection at 8 ohms is 8 ohms/0.005 ohm (5 mohms, milliohms) = 1600, at 4 ohms it would be aprox. 800. These values are pretty typical for high power amps with lots of output devices and power reserve, so, IMO, very on par with most other high power solid state amps, in fact much higher than some especially considering the amount of raw current these amps could source to the load. Perhaps in the industrial world, damping factor, as a calculated number, is not so much a real world spec in the world of shaker tables and MRI power supplies?
In reading the 7560 PDF specs noted in the link above, all of the specs seem to be similarly stated to any typical audio or professional audio power amp. THD and IM distortion over frequency range and power bandwith, power output at frequency and load impedence, straight DC current output (20A, yikes!), frequency response, slew rate (32v/usec), phase response, etc. etc. Techron/Crown always published conservative specs so you can rely on the specs to be bettered with proper functioning and maintainence.
As for the input sensitivity, 3.3V for rated power is well within the range of professiional gear used to drive amps (professional and industrial) of this type. Usually output of preamps, mixers and line amps will be on the order of 5V plus. Most general consumer preamps should be able to generate something close (3 volts or more) from their line amp sections. If the preamp is unable to push that much (say 1.5V output would still get you 400 watts), that is a problem with the preamp. Also, input barrier strip can be wired directly to additional cards that can provide for preamplification if the driving source has a limited drive capability. See Special Input section on spec sheet near end.
For consumer examples, the venerable 1977 Dynaco PAT5 could put out in excess of 10V into >10,000 ohms. The PAS3X during Stereo Review testing in 1966 put out 4.4volts into an unstated impedence but likely over 10Kohms. The 1979 APT Holman preamp drives with "undistorted output of at least 7 volts". So unless preamps have much less drive today, they should be able to drive this amp.
I've used a number of Crown amps in professional PA / Church work and they are solid, strong workhorses, that most of the time sound fine to great. Techron products are an offshoot company catering to the industrial use crowd but strongly based on the same Crown technology developed for home and professional use. I would expect and see the same committment to quality, robust to tank like construction and reliability that regular Crown products have.
