Do those 1250s come with solder tabs or do you just wrap wire around the end of the post and solder it? Just curious as I don't see any tabs in their photos.I've used both the 091-1150's (shown above) and the 091-1250's pretty much on every speaker I've replaced them on. The 1250's are my pick because I just like that design but right now, they are a little higher than when I bought them awhile back. They had been $9.90 for a pack of 4 which was enough to do a pair of speakers. They still aren't bad at $11.33, though.
http://www.humanspeakers.com/e/epi202.htm
I looked at the crossover schematic and IMHO you should leave it as is and just replace the caps and posts. This has a switch to set impedance on one side and a pot on one side for the tweeter (bright/less bright). I hope the pot is OK, mabye need cleaning. This will be an oustanding speaker when completed.
:tresbon:
