Check Cold solder joints on Power supply PCB. I find this all the time.
John.![]()
So, I finally deox'd all switches and pots. Still no joy. Checked output of CN3 (voltage to motor) and all is good there at 120V according to my multimeter. So I know the motor has power going to it. But no life in the motor. I'm not sure I have a way to check the motor itself. The spindle moves freely so I'm sure it's not locked up.
At a loss at this point.
And here it is right side up. LOL
Just an idea, but have you done a continuity check of the motor with it removed? If you are not getting a positive reading, that may mean that the motor windings are burned out. It seems unlikely though...
Snip! Could I hook the motor up to a different power source to see if it spins up?
Can you take a close look at the capacitor i circled and confirm that it is NOT bulging? When I zoom in on the picture it looks as if the top of the cap is bulging, if it is in fact bulging, that could be the culprit.
Doesn't appear to be, nope.
Ok, good!
Is the fuse good? (silly question, yes I know.)
Where can you download the Service manuals? I have a Denon as well.
Appears to be fine.
Would I get 120V in the motor output of the power pcb if it was blown?
