Command8
I did all those measurements, everything was going fine, measured and set idle current to 25mv, right side was spot and and left side jumping a bit tp 24.2 to 25mv.
Let the amp run without the DBT, it was fine for about an hour after that BLAM.
All output transistors but one shorted and blown.
(these measurements were before the output transistors getting blown)
q309 Vb 0.59, Ve 0.002, vbe 0.6
q307 vb 0.6, ve 0.002, vbe 0.6
q305 vbe 0.569
r313 0.0026 voltage drop
q301 base -0.085,ve -0.7
q302 base 0.002, ve -0.7
r302 measures 51kohm
I changed them all again with my last pair of MJEs, and now another short from the DBT. I've identified and changed diode D556, something else is still shorted.
The TDA7293 option is seeming more and more viable with all the heartache this PA is giving me.
q305 vbe 0.569
