Ive been trying to show better pics, so here are some pictures of markings on amp. Notice what seem to be two volume pots one where some jacks used to be.:scratch2:
Something must be very strange about the OPTs on these amplifiers. They appear to require a decidedly unbalanced drive to achieve best performance. Take a look at the plate and cathode load resistors in the phase splitter circuit. At 33K and 22K respectively, the set of output tubes driven from the cathode leg are only receiving 67% of the drive that the output tubes driven from the plate are. It's like that in both versions. I've never had any experience with either of these amplifiers to performance test them, so does anybody who has know anything about this aspect of the design? It really is very strange.
Dave
This one, perhaps: http://www.audiokarma.org/forums/showthread.php?t=140121...If you search around the site for posts by Micah (Bricktop), you'll find his modded Bogen circuit. It's a huge step up from the Bogen's and allows you to run EL34s or KT77 in place of the 8417s. The sale of the 8417s could probably pay for the mods to turn that into one of the best tube amps you'll hear.
IIRC KT88s should be fine with the voltages but might need some re-bias; 6550s would be on the edge though.... KT88s might be scary to run at the voltages the bogens operate at.
this thing has been modified for stereo
As for me; I believe your MO-200 Mod your falls short of It's true potential,
Modifying a Bogie MO-200 into a stereo rig won't get you there. It seems to be a cookie cutter solutions.
why exactly do you believe that?
So what are the details of this mod? Please share.... The task at hand for my third project (as mentioned in my previous post) was to rethink my two remaining
Bogie MO-200's, with both amps operating in unison (side by side) together in a reworked mono dual
channel arrangement including a variable frequency specific OPT circuit stage which allowed me the
ability to greatly exceed (without exception) the overall performance of the paired Bogies in stark contrast
to a typical Bogie MO-200 stereo Mod. A mod "mind you" that has performed and proved Itself worthy in
reproducing fawless music time after time in conjuction with a pair of !5" Tannoy Golds and a quintessential
preamp hub, making this core audio system true force to be rekoned with...
Never heard of such thing. Can you post a schematic so we can all see what you're talking about?
