Bohlander-Graebner Planars
Nope, but I do have the Neo3's and am very, very impressed with their performance. I'm anxious to hear your impression of the Neo8's as I'm seriously considering a pair of Neo10's to replace the EMIMs that were harvested from these RSIIa's.
picture.php
What are you planning on using the 8's in?
- Michael
As much as I love my Dayton full-rangers, I'm thinking it's time to experiment/upgrade. I will be crossing the 8's in at 500, lowest point mfr. recommends. These will be powered by my rebuilt/highly modified GAS Grandson (it really sounds like a little tube amp).
My stack of 2x12" on each side will handle 500 & down, powered by the Son of Ampzilla.
I use the B&G Neo 3s ( see avatar ) with Tang Bands W8-1808 in OB and drive them with their own dedicated T-amp.
They give incredible shimmer and air to the top end and high hats never sounded so good.
You might want to look into that 500 Hz xover point a little bit more. Read the testimonials/reviews on PE's website. Seems I read somewhere they can only pull off the bottom end of the manufacturer's stated usable range when used in a line source config.
Yeah, I saw that. My experience with line arrays has always been lobing issues. There's a poster on PE that says he's crossing them over at 300 with good results though...
Ah, let the experimenting begin
I like your attitude. :thmbsp:
Just floor it and let's see what the sonofabitch will do! :D
I did a 2-way with the Neo8 and a 6.5" back about 10 years ago. I remember they sounded pretty good but I had to use a cap in a compensation role like with a horn to get the response flattened out. After doing that there was a bit of a drop way up and the high end (like 18k-20kHz or so) but didn't show up in listening tests. I seem to recall the crossover being somewhere in the 1000-1200Hz range.
"I had to use a cap in a compensation role like with a horn to get the response flattened out."
Elaborate, please.
WHEN AMPZILLA SPEAKS, PEOPLE LISTEN.
I'm definitely following this thread with interest.
Please do post all your impressions, good, bad, or indifferent.
jaz
Elaborate, please.
Remember that this is from 10 or so years ago so I hope I'm remembering the right driver (I've designed quite a few speakers since then). As I recall, the driver had a rising response that went up roughly 6dB per octave starting somewhere around 3 or 4kHz and going up to about 15kHz. To counter that rising response I put a capacitor in line with the driver (a single cap will have a 6dB/octave falling response as frequency increases). This made the response up to about 15kHz or so pretty flat at the expense of the very highest treble.
A capacitor will block low frequencies at 6dB/octave, and pass high frequencies... Do you mean an inductor?
has anybody used/heard the new Neo10? (PE's price shot way up though). it plays much lower apparently, though it would need a tweeter. that one interests me though!
Great googly moogly! I can't believe I did that. Yes, of course I meant inductor. Thanks for correcting that. It's not like I do this stuff for a living or anything. :D
I used an inductor in a manner similar to a cap in a horn compensation circuit to flatten out the rising response.
Egads. I should be beaten for that goof.
Ray, is what you did the same thing as "notch filtering"? I read the larger Neo drivers might require that in certain applications. I think Tom Brennan mentioned it in a discussion once as well.
Neo 8
Just a word of caution.These drivers are very easily damaged if too much heat is applied when soldering to the input terminals.I recommend using lugs instead of soldering directly.This was a very expensive lesson for me.
What I did was kind of like half a notch filter. A proper notch filter would have preserved the high end of the spectrum at the expense of a slightly more complex filter. At the time I was just looking for simplicity and it ended up sounding pretty good so I left it.
all the planars exhibit a peak in the response. they even call it " Bohlander-Graebner resonance". my old carvers also had this peak caused by the unavoidable cavity resonance from the driving magnets in the frame. not a big deal in practice, just a passive notch is all that is needed, or a para-eq in the front end.
