belgiansound
Member
Thanks for your reply! Never used a variac and I don't even own one, only have a multimeter..., but I get the idea, disconnect everything from the other side of the transfo to measure the primary circuit, slowly raising the current to avoid burning again everything.
I'm looking now into buying one 2nd hand as it may be usefull anyway.
I'm also waiting for my new resistors as the current one is blown, so no chance to do this test now.
Stupid question, but when I deconnect the diode bridges, I can disconnect the molex connectors on the boards as well as the transfo is not doing anything (besides being measured while I crank up the current slowly using the variac). I say it because in the second step you say 'disconnect molex connectors', I would do this anyway to avoid any damage by stupidity.
Talking about stupidity, I still don't get why I have a problem now. I used the amp for two weeks (on my spare speakers, to test it, i didn't care if they got blown they are Bose) without any issues, and I only rebuilt both boards and put a new rectifier bridge in. I'm really baffled.
The fuse is a TD-3AG T8 so it's a time delay size 3AG, but not to clear what the 'T8' means. There isn't any brand mentioned on the fuse but my guess would be it's 8A 220V, according to the manual it should be 7A 220V slow blow.
