The lamp works kind of like a varistor. As more power is fed, the lamp lights up AND changes resistance (increasing), and sparing damage to the driver in series. Based on input from others (Bose and RS Mach Two owners) the lamp does it's job well, however, I'm thinking that the lamp degrades (as lamps do) and the resistance, unfortunately increases, diminishing low power performance. Based again on posts, the difference can be significant. The ones used in RS speakers are 12v 27w (if I recall correctly). I wouldn't be surprised if the Bose is close, maybe even the same. These lamps are still available through many sources.
Hope you'll post your thoughts on them after you've given them sufficient listening time. What series are they?
Post an image of the networks, if you can display the values of the caps. Those are fairly common values, shouldn't have trouble getting those.
