Copa1934
My ears are bleeding
The caps should be for the other drivers. Usually a coil (attenuator) is used with woofers to trim off the higher frequencies. Of the poly caps I've actually tested, all checked out fine, in fact they were within +/- 1% (all were actually less than 1%). So, while I don't believe you've made an error, unless you test you won't know if one or more have been damaged due to misuse or abuse.HAHA, zombie THREAD!!!
So, I've been enjoying my Bose 601 series II's I restored for awhile now. I refoamed, scrubbed and washed all the plastic bits and grills, filled in the slight scratch on cabs, and replaced the resistors, which had broken and pulled loose from the housing.
I saw poly caps, so I did NOT recap.
Was this a mistake? I remember reading the woofer naturally rolls off, and didn't figure poly caps would need replacing.
Anyone able to chime in with some experience on this??
And for anyone who says Bose sucks, I disagree. These are very enjoyable, if atypical speakers.
If the speakers sound as good as you would "expect" them too, which is not the same as saying as excellent/bad as others would say, then you likely have good caps.
If you feel the difference, compared to other speakers you own, is only subtle, again the caps likely are good.
Are these the speakers you gave me the option of taking off your hands? If so, very glad they are meeting with your approval. I'm still keeping an eye out for a pair closer to home. Very difficult to come by.
