That may be the music they were designed for. The Dentons for Rock and Roll![]()
I should just keep em all then doncha think!
You knew that all along.
The B&W's are back in the game. Man they sound great with classical. Been listening to classical Christmas music all day.
If you want to play rock with 685s, just add 15-18" sub. That is all you need, you will feel PRaT too. They won't hide poor record mastering though.That may be the music they were designed for. The Dentons for Rock and Roll![]()
You do need sub with 685. They do not have much output below 60Hz, and are not very linear below 100.Don't need a sub to play rock. The B&W's are a fine all around speaker. Just have to be patient and run them in. I don't use a sub with any speaker and enjoy every genre of music. I have nothing against subs, for someone else, not for me. To assert that all you need to "feel" PRaT is a sub is simply not true.
A good loudspeaker allows you to enjoy all of your music, poor mastering or not. That is always what I am looking for. Good resolution, tonality, timing and non fatiguing.
Good speakers truthfully reproduce what is recorded. In most case it means that poorly made record is unlistenable, as sound defects are obvious. If speaker hides defects (adding its own distortion on top) it is not truthful to the source.
I got the impression that he meant the B&W needed a sub to sound good with rock (whether that's the case or not).
I knew what he meant. He is wrong.
Most rock concerts I've been so far had rather poor sound. Loud - yes, but quality - mediocre. I can reproduce at least smaller venues sound using my system. My speakers are more expensive than 685 though.The bolded part is the key. Everyone has different ears and different tastes in what is perfect (or getting close to perfect) for them. That is why there is such a vast array of equipment in this hobby.
I do use 685 as surround in my family room setup though, so I am familiar with the sound. All 600 series was designed with assumpton that subwoofer will be used, so no reason reject it. Properly integrated sub greatly improves sound of almost any speakers.
