Retrovert
Addicted Member
Anyone have thoughts on incorporating an external tweeter, (in my case, a Morel), to the inside of the Symphony without major surgery to the cabinet? Perhaps replace one of the existing y tweeters with a soft dome, wired/ and band passed as it is now?
Disclaimer: it's late and I may have butchered the math, so I'm showing all the work.
Bozak Cult Rule 5: Loudspeakers are competing forms of millenarism seeking to immanentize the audio eschaton, so experimentation upon Bozaks is not merely encouraged, but respected, even when it fails, as true knowledge must be painfully acquired.
If I correctly recall, the tweeters are something like series wired to yield 32 Ω pairs, then two pairs are parallel wired to yield 16 Ω, and two pairs of those four are parallel wired to yield 8 Ω:
(16 Ω + 16 Ω) || (16 Ω + 16 Ω) || (16 Ω + 16 Ω) || (16 Ω + 16 Ω)
= 32 Ω || 32 Ω || 32 Ω || 32 Ω
= 8 Ω
= 8 Ω
It is not possible to simply remove a tweeter without rewiring the connections, because the Impedance will change from 8 Ω so the crossover will no longer be at the proper point:
(16 Ω + 16 Ω) || (16 Ω + 16 Ω) || (16 Ω + 16 Ω) || (16 Ω)
= 32 Ω || 32 Ω || 32 Ω || 16 Ω
= 4 Ω
= 4 Ω
Padding that out will sound terrible.
So obvious (pass 1) solution is to drop down to two tweeters (16 Ω || 16 Ω = 8 Ω). Naah, that's silly, for we at Bozac Cult are clever (pronounced "crazy") and can do better.
Four tweeters can be made close enough:
(16 Ω + 16 Ω) || 16 Ω || 16 Ω
= 6.4 Ω
which permits a 1.6 Ω padding resistor to yield 8 Ω, albeit with a slight loss in power (impact upon damping factor for a tweeter should not matter).= 6.4 Ω
But let's see if we can do better so we don't get kicked out of Bozak Cult for not thinking it through.
Observe that five tweeters may be used:
= 32 Ω || 32 Ω || 16 Ω
= 8 Ω
= 8 Ω
Which permits a super-tweeter to be added without an impedance change, but at the cost of losing three tweeters in total. Not to worry. Those B-200 tweeters needed an L-pad anyway, so now they'll need less attenuation.
Et voila! The crossover need not change, nor does the super-tweeter bandpass.
Different impedances could be for the super-tweeter with a re-designed band-pass for the super-tweeter — two 8 Ω tweeters in series = 16 Ω, so halve the capacitor and double the inductor — but the load line would shift in a tube amplifier. Distortion would result, but it's high-frequency where humans poorly hear so very likely not significant.
