Can't tell from that pic. If you remove that center screw, the cap can be pulled off revealing a # stamped in ink on the magnet. That will tell you the age.New project in the works. Below is the label on the speaker. What year would this be?
Thank you for input. I was hoping you would see this post. You are the Bozak guru.They’re 1950’s with the early B199 woofer, paper B200x tweeters. The woofer is a low excursion version for lower power tube amps. Be careful with solid state, easier to blow. My favorite cabinet design, mmmmm.
The paper ones correct? Not the spun aluminum mids. Found this document on the kit assembly. File too large to post. Link is to the web page. Page 22 1958 06 June issue. https://worldradiohistory.com/Archive-All-Audio/Audiocraft_Magazine.htmYou should be able to find a pair of 1950s mids for dead cheap.
That will likely be the course of action.My B-305 came with the Kimsul. Still has it because I lack the time to make it a five-way. Kimsul is horrible stuff. Must be replaced with cotton batting.
That is an interesting piece of data. Thank you for the scans.The E-300 was discontinued by 1959.
Rule 19 of Bozak Cult: The glaring inconsistencies, continual revisions, and seemingly randomized assemblages present in Bozak's nomenclature, driver and crossover numbering, years of use, crossover points, cabinet designs, quality, and manufacturing techniques, and units found, all combine to make it perfectly natural to be routinely confused, if not outright baffled, and have evolving understanding, so do not sweat it if once in a while your assumptions prove incorrect or if it takes multiple attempts to understand any particular configuration.
