Thanks for the reply. I currently have AR3a’s hooked up and AR 2ax’s in reserve. Would you consider the Bozaks a good upgrade? At almost two hundred pounds per speaker, I’d have to imagine they are in whole nother league, right?The Bozak Concert Grands little brother, should be a very nice speaker. I've had a few of the later, smaller Bozaks and really liked all of them.
The date code would be the the month number followed by the year. 0876 for instance. Most of the time in the Stereo mode I use about 2 watts with the Grands. In the HT mode the 4005 being the most important speaker is about 2 to 4 watts with 20 watt peaks. But with Techno movies a rare occurrence might require 50 watts total. When I had original 4000 symphony's I used them with a MC 240 for many years very happily.$900 with a little room for negotiation, but I also don’t have any kind of reference point because I can’t find any for sale.The Bozaks are tube friendly. And they put out incredible sound. What do consider a great price?
You really want speakers built after 73 as they have the better speaker capacitors. While the older units have the better air coil inductors and will have to have the crossover capacitors replaced.
Remember Alnico magnets loose their strength with use especially if the units are pushed consistently to hard. My Grands are Alnico everything else is ceramic. I bi amp and tri amp so that. gets rid of the majority of caps. There are 5 N-107's in the system and the caps have been replaced. The Grands are tri-amped, with the one cap of the N-107. The symphonies are Bi amped with the one cap of the N-107. Only the 313's have the full N-10102A crossovers. They have been recapped also. When I took out all the caps of the 4005's they all measured with in 2% and their DCR was less than 0.2 ohms. I quit rebuilding Symphonies at. work in 2004, when I retired , adding super tweeters, checking wiring and cap replacing them most of the time. . All were pre 200Z tweeters and they all measured the same after additions and cap replacements with in a db or two. I maybe converted about half of the older units for bi-amping. The N-105's were tossed. I never did Tobin mods back then. Fortunately I never had to deal with the older Bozaks with with paper tweeters and midranges. I kept records at work but the store closed 5 years ago as I remember and all that paper work is gone. I still help friends with ML series speakers and rarely a Bozak owner. They have mostly past on as they were 10 to 40 years older than I was when I started work in the late 60's when Bozaks were so popular. I always wondered what happened to my B4000 Contemporary.
