BillWojo
Addicted Member
- It must be able to locate the starting point manually and, once required, be up to speed almost instantly, much less than 1/2 second. This is usually achieved by a dual platter: the lower platter is in constant rotation, while the upper platter is separated fom the lower platter via a velvet (usually) layer which transmits the rotation to the upper platter with a calibrated torque. After cueing the record, the lower platter starts spinning while the upper platter is held by a mechanical brake shoe on its side. To start playing, the brake is released and the upper platter speeds to normal speed almost instantly. Same thing for stopping, you just press the brake shoe and the upper platter stops.
2 piece platter is very rare and I'm not aware of any popular broadcast TT that use that. On my Russco Studio Pro idler drive the engineer would back cue the platter to the starting point, engage the idler and than could start the motor from his console. The platter comes up to speed in well less that a quarter of a revolution. 3 out of 4 of the Russco TT that I've had used a solid state relay to turn on the motor, control wires were still hanging off the relay where they had been cut.
Also,for broadcast it is almost compulsory to have a built-in preamplifier with balanced line level outputs, since radio mixing desks - at least the serious ones - don't have phono preamplifiers and radio stations didn't care to bother with external preamplifiers - at least, not those that I've known.
I know the Russco TT were generally sold without a phono pre, that was built into the mixing board that the engineer used. Sounds like the stations in Europe did things very differently.
BillWojo
