Broadcast turntables?
Personally I've never seen a broadcast mixing desk with built-in phono inputs, but if you remember names I am genuinely willing to learn. External preamplifiers were commonplace in the community radios that used DJ turntables, though.
As far as I know, no radio mixing console had built in phono pres and it makes sense. Given the usual set up of a control booth, you would have needed a very long cable from tonearm to the patch bay. Even with the lowest capacitance cabling, you would still have gone off the mark for most cartridge loading, and since moving magnet cartridges are single ended, the susceptibility to noise would have been prohibitive. It was much more logical to use stand alone pres mounted as close to the tonearm as possible with balanced outs so cable length and noise pickup wouldn't be an issue.
Cogging is not measurable in wow, and very difficult measurable in flutter, as the speedvariations are so short.
I've never seen anyone showing test results that demonstrate "cogging", the mass of the platter smooth out any pulses if they are present at all. This "cogging" was largely made up by the British audio press to save their TT manufactures from going out of business like the motorcycle companies did when the Japanese showed up on the scene. If anyone could have proven it, the British would have done so, as it is, they tarnished the reputation of good DD tables and some folks still believe this crap.
BillWojo
...I've heard certain idler drive models referred to as broadcast tables (such as the Garrard 401), but also the same term used for direct-drive models like the Technics SP-10 and Sony PS-2251. Were there any belt drive models that were considered "broadcast" decks?
Amazingly enough, the belt driven Empire 298 turntable was used as a broadcast turntable for many classical music and "beautiful music" radio stations back in the early 1960's. Testimonials from broadcast engineers used in their ads stressed the low maintenance needed along with the quiet rumble free operation. Tight cuing would be almost impossible of course, but that wasn't really a concern for classical/muzak stations at the time.
I also get the impression that some (many?) of these decks were sold either without a plinth, or could be purchased with an optional factory plinth in some cases. Is this true? What about the armboards?
It's true, because most turntables were mounted directly into custom furniture. Although in this application, the optional factory "plinths" were a big two to three foot high cabinet made mostly of metal than what we consider a plinth today. As for armboards, they weren't used. These cabinets were usually much wider all around than the deck, so you drilled a hole(s) and bolted the tonearm to the top of the cabinet after the deck was mounted to the cutout in the top of the cabinet. It was the same when the decks were mounted to custom console furniture. No armboards, just holes directly drilled into the top surface. That's why you see so many different holes in some of these cabinets when they come up at auctions or old radio station "fire sales": upgrades to tonearms meant a new hole.
Probably not a broadcast table I picked up at an estate sale. KS Musicmaster Point Two Five. Circa 1959. It does have a MM copy of the Gray arm from what info I can find that was used in some broadcast tables.
That is very debatable. The SP-10/15/25 use a cored DD, whereas most hifi tables use coreless DD's.
Recently technics also switched to coreless (although they also made coreless DD's in the 80's, but the classic sl-1200 and such are cored).
The advantage of cored DD is that they start and stop really fast. The motor is much more powerful.
Downside is that the core is iron, so as the platter rotates, it is also attracted to other cores as it spins. This phenomenon is called cogging.
The first coreless DD (I think) was the dual 701. Totally not suitable in a studio enviroment, but as hifi drive arguably better. In the early 70's dual catalogs the phenomenon of cogging was already explained, so it was already known back then.
If this is a sonic issue of importance, everyone for themselves has to make that out.
I am yet to hear a Dual that outperforms the SP10 ;-)
I have no idea how an sp-10 compares to a TTS-4000 or PS-2251. (I think both these have a cored motor too)
These two Sony models don't have permanent magnets in their motors, they have copper drag cups, so the presence of iron armature is irrelevant.
Transcription player?
Nowadays, while there might be claims by companies, saying that they are producing transcription turntables, it is not the same. This is because the word ‘transcription’ has been loosely used for the turntables. All the current transcription turntables are just turntables that is able to produce Hi-FI sound, which means High fidelity sounds. However, they sound nothing like the original transcription turntables.
True, but that doesnt mean it isn't there. I only see flutter measurements according to din/iec standards. And if that type of test isn't right for that effect, than you can never see it in specs.
Afaik it was Dual who wrote first about it, with their launch of their first DD tt in '73 (so the SP10mk1 was only on the market for about 3-4 years by then and there were maybe a handful of other japanese DD turntables (sony?). Of course Dual had a german word for it. "Polfühligkeit" :D
And later most japanese turntables aimed at consumers and high end were startup and brake times were not important also switched to coreless.
And now technics say it themselves too
Technics also made coreless DD's in the 80's btw, just like Denon, they did both.
I guess anyone can make up their own mind on it. The only thing I know is that the EDS-1000 motor that sat in the Dual 701 50 years ago looks remarkably like the motor now in the SP-10R and SL-1000R (turntables costing around $10k and $20k)
The dual EDS-1000 had 16 coreless coils and the SP-10R/SL-1000R has 18 coreless coils (most coreless DD's in the 80's had 4-6 coils):
EDS-1000 coil array:
file.php
SP-10R/SL-1000R:
mr_petit, you got me wrong - which usually means I didn't explain well enough, sorry about that - and it's not a matter of semantics. I answered to you regarding the difference between a transcription turntable and a broadcast turntable. If you read Taketheflame's question, it was not at all about what turntables can be or have been used in a radio station (I've seen any kind of turntables used in radio stations, although not all with the same success). It was about "broadcast turntables", ie. turntables designed for use in radio stations. My answer is that those turntables have specific characteristics that don't bring anything useful for home listening, only more complexity and possible problems. Discussing offshore radios is interesting, but I don't think it adds anything useful to the current thread so I'll leave it at that. Thank you for pointing me to a photo of how the BBC used TD124's in their local stations.
So is buying a typical non-rebuilt example of a broadcast deck (over a gently used TOTL or close consumer deck) akin to buying a decommissioned cop car instead of a gently used garage queen?
That is a nice way of putting it, and unfortunately it is exactly true. You cannot even tell from the external appearance, as many pieces of equipment were used 24/7 for many years and hardly touched at all, so their internals are shot but they look mint.
What is there to look for besides the obvious like unusual noises or bearing play?
Several things cross my mind:
  • Wow and flutter, speed accuracy if not adjustable. If you cannot measure, bring a record of piano: this is by far the best instrument to reveal speed fluctations - including cogging.
  • Condition of the rubber and plastic parts, and of the springs - for instance the hinged lid, and the anti-skating if it is of the spring type. Belts can be changed, idlers can be rebuilt (usually), but at a cost. For some important plastic parts like cogwheels, any crack is a showstopper as you will probably not be able to fix it and spare parts are usually unavailable.
  • Condition of the stylus (often more difficult to assess). Always take in consideration the cost of replacing it. This is even more important for many "true broadcast" cartridges (EMT, Clément, etc.) which are hard to find, and prohibitively expensive.
  • Does the tonearm have a standard cartridge mount? If not, can you find an adaptor? This is particularly important if the stylus is shot. Again, assuming you are buying a broadcast turntable as several makers had their own standards.
  • Does the platter spin freely? Is it flat? (it might have fallen)? does it wobble? (the spindle might have been bent)
  • If the turntable has an internal preamplifier (commonplace in broadcast turntables), make sure that it is working properly, that the relay and connector contacts are good (no scratching noise, no buzz, no bad ground). It is a good thing if you can defeat it and connect the cartridge directly to an external preamplifier. Internal preamplifiers usually have balanced outputs with a "hotter" level than your unbalanced amplifier expects, so be prepared to add an attenuator if needed.
  • If the turntable has a dual platter, does it make good contact? (otherwise it can slip when starting and stopping) What is the condition of the intermediate layer, if it uses one?
  • Personally I also check the availabilty of a service manual, download it and read it before I go to check the turntable, in order to identify the possible critical points, but that's the engineer in me.
There are probably many more things to consider, I'm sure someone will join in to add points to the list.
1. Any distinctive advantage or sonic character that a rebuilt and modded idler deck offers over DD?
Why do you say modded? What kind of modification would you like to do?
Personally I find both technologies attractive, although idlers are definitely noisier, but usually not so much that it becomes noticeable. I too have heard about the cogging of direct drives, but that's a theoretical possibility if the design is badly flawed, in reality I have never heard a cogging DD motor, and I don't see how a manufacturer would botch the design of its turntables to the point of cogging. This is just Dual's sales pitch, it does not describe what the other manufacturers did IMHO.
Regarding the "sound" of idler drives, audiophiles came up with the concept of PRaT (Pace, Rythm and Timing) to account for a difference that they hear in the music rendered by some idler turntables. Other PRaT believers find it more in the Revox B790, a direct-drive turntable. Personally I have never noticed that. If I had to find a difference, it would probably be in the cartridge and in the serviceability, rather than in the sound of the spinning record.
It's fairly easy to see for yourself with standard equipment, however. All the W&F meters can measure unweighted values, and have an unweighted output for spectrum analysis, so you can see cogging and even measure it if is is there.
But this discussion is completely different from Taketheflame's questions.
I can't hear with your ears. It's a personal experience.
Interesting, I didn't know that. Usually eddy current motors of that style suck at making torque.
Well tell me how a DD motor can "cog" a platter that has a lot of mass than. Even a 3 lb platter on a DD table will have a lot of inertia and the thought of accelerating and decelerating it many times a second is baffling to me. It would take an awful lot of energy to do so, magnitudes more energy that the typical DD motor draws. From a physics point of view, it just can't happen. It's why it's never been measured, you can't measure a myth.
Have you ever worked with large 3 phase servo motors? It's amazing how smoothly they can run at slow speeds. A lot of that technology is used in DD motors as well. If cogging were present in those servo motors, it would show up in surface finishes when used in precision milling machines. The old stepper motors used to clearly show defects in the surface finishes.
Maybe it was Dual who first wrote about it but it was the British press that pounded it into everyone that would listen. They made DD turntables an embarrassment for audiophiles to own. Of course for those who could think for themselves it wasn't an issue and they went on to purchase some of the finest TT ever made and still highly regarded decades later.
BillWojo
I’ve built several “Broadcast” turntables, most were idlers, however Fairchild had a few belt drives that were also used in commercial endeavors, I’ve seen one 412 and a few 750s set up for DJ use.
The big idler’s are special and with modern materials/parts and a well designed plinth they can be made much quieter than the LP noise floor.
My Builds:
Rek O Kut (ROK) Rondine Deluxe B12H
ROK TR12 & TR43 Therese ar very special tables the TR12 is 33/78 and the TR
43 33/55
This one will get passed down to my Grandchildren View attachment 2635381
As @BillWojo mentioned the Russco Studio Pro, sometimes confused with the Cue Master, but the Pro is a much better machine 33/45, another machine I’m keeping.
And for good measure the Fairchild 412-1, my version. ;-) asynchronous motor and dual belt drive, motor to intermediate pulley then intermediate pulley to platter….another heirloom
My understanding is that a few Thorens TD 124’s were also used in Broadcast
VR
Andy
:beerchug:
No it doesn't take a lot of energy/force. It all depends on how much acceleration/decelleration. Tiny bit of acceleration/decelleration requires tiny bit of force. Large bit of acceleration/decelleration requires larger bit of force.
Anyway, it's something Technics are saying too.
Ok, you can settle this by showing us verifiable test that show this cogging. Maybe Technics has such test. Very sensitive accelerameters exist that should make measurements easy to obtain. At that point we can calculate what the effect is on the speed if any.
By chance, do you work for the British audio press? (just kidding).
BillWojo
You have a verifiable test that examens this in great detail and doesn't show cogging?
I mean it cuts both ways and I think both arguments are difficult to proove.
But Technics says it. After making cored DD's for half a century. I don't have the means nor the knowledge to proove them right or wrong. You don't either.
Nor do we have proof of if it is or isn't audible. But that goes for loads and loads of specs.
Fact is that they switched technology and that they came up with a motordesign that looks remarkably like what dual or pabst came up with 50 years ago and puts it in $10k+ turntables.
You may not like dual, but you can't deny the resemblance. And it's afaik the first one in 50 years that makes it this way with so many coreless coils.
I'm sure the regulation with quartz is way more precise and slew rate of the semiconductors is way better, the magnets are far more modern and more powerful etc etc so the Technics version will outperform the Dual one, but half a century difference and a considerable amount of money difference is there too. Having it not outperform would have been an achievement (of some sort....)
The first eds-1000 in the 701 was even outfitted with germanium transistors....thàt old :D (and one of it's weaknesses for sure)
Believe the clogging claim was a very effective propaganda anti DD advertising scheme:naughty: If clogging was truly a phenomenon, it would show up when hooked up to a W&F meter, the speed would flutter thus being self evident.
Can tell you that my Denon DP 75 has never done anything that could be called clogging…
One has to remember that idlers dominated the Broadcast market for something like 40 years before the first DDs came on the scene and it was start up time and dependability that made them so successful.
The ROK Rondine Deluxe B12Hwas used heavily in broadcasting but also available to the general public as a very successful high end consumer product.
The big broadcast idlers, like ROK, Russco’s, QRK, Gates etc… are way overbuilt, and require very little in maintenance & parts to make them actually better than new. Change the rubber mounts, new idler, maybe clean the motor, add oil and boom it’s ready for another 50 years!
The cop car analogy doesn’t apply at all,:no: it will take several lifetimes to actually wear one of them out…
Idlers deliver what some have called “slam” more defined bass, tighter, crisper, and other adjectives :blah:
When playing tables at home my unconscious inclination is to play one of the idlers over my other tables, whatever that’s worth ;)
VR
Andy
Let's say it this way: torque ripple in cored DC motors is real, but...
There is a large thread with polar plots from various turntables over at DIYaudio, and so far there has been no evidence of cogging from any Technics DD turntable. I have not created a polar plot for my own SP10mk2 since I don't own a good enough test record, but the output of the motor's built-in frequency generator is a remarkably clean and absolutely stable sine wave. I'm about 99% sure it would not look that nice if the motor suffered from detectable cogging.
