Bugle Boy 12AU7 tube ID?
Late 50's
57-59 era is my guess
Towards the bottom of the glass you should see some etch codes similar to the ones in the pic of an Amperex 12AU7
They will give you the info you're looking for using the info from the link below.
In this example the codes are,
k63
⊿7D
k6 = change code for 12AU7/ECC82, the 3 is if I'm not mistaken the 3 iteration of that type
⊿ means manufactured at Philips's Heerlen Netherlands plant, 7 is for 1957 D is For April
It's acid etched so it wouldn't of smudged off
Looks like a 7 to me so maybe hone in on that using a magnifier or a bright light
OK thanks. Legally blind guy so that doesn’t help. Wife is out of town. I did try to blow it up with the phone but to blurry. Not a big deal. Just curious.
Was not aware of your vision issue if anything I posted came off as insensitive then you have my apologies.
Fwiw
I'm of the belief that back in the late 50's they weren't counterfeiting Amperex tubes. So I'm pretty certain that what you have in your possession is indeed an original more then likely made at their main plant in Heerlen.
Should be a nice sounding tube!
If interested here's some variations on the "Bugle Boy" himself. I never found out at what point in time did they change design
Treble Clef version
I believe that the top Bugle Boy logo was the earliest (1950-60s). The bottom one is the latest (1970-80s).
The bottom one is one of mine and I'm pretty sure it's 1957 based on
k63
⊿7H
Hadn't they already transition away from the Bugle Boy to the Globe logo prior to 1970-80's
I have this one which 1969
k63
⊿7H
Yes, you are prolly correct. There was a lot of overlap of logos and font styles in the mid 1960s to late 1970s.
I kinda remember Richardson bought that thin Bugle Boy logo from Philips (your third photo) --- for some of their relabeled tubes in the 1990-2000s. That's why I thought that was the last of Amperex BB logos.
k63
⊿7H
Bugle Boys and Telefunken 9-pin minis were the first "hot" items I remember both audio and guitar guys lusted after. This is back in the 1980-90s. I didn't buy many BB tubes. More TFK.
I really like the Amperex BB EL34. Somehow, their prices didn't go through the roof, like xf 1 and 2 Mullards (Blackburn made).
