chicks
Lunatic Member
A Squeezebox Touch clone with a 4" touchscreen.
1. Download piCorePlayer, Standard (32-bit) version, write to a micro-SD card.
2. Set up wpa_supplicant.conf per instructions, save to the SD card, so that the pi will connect to your WiFi.
3. Put the micro SD card into a Raspberry Pi Zero WH.
4. Mount the Hyperpixel 4" Touchscreen to the Pi Zero. (Also available here).
5. Follow these instructions to install Jivelite, the touchscreen drivers, and calibrate the screen.
6. Connect the USB DAC of your choice (or no DAC if simply controlling another SB). You'll need a micro-usb adapter cable for most desktop DACs.
7. Point your browser to http://pcp.local to configure the DAC.
8. Mount the Pi assembly to this stand *, using bolts and nuts, for a very stable mount with adjustable angle. Will have to drill a couple of holes in the stand (it's plastic, I drilled them with a manual hand drill).
9. Enjoy some tunes!
* For some reason, AK is redirecting this Amazon URL to Wally World, though it points to Amazon. It's cheaper on Amazon. https://www.amazon.com/gp/product/B017TU5KMQ/
Anyone know how to tweak an existing 3D printer model?
