outlawmws
On the Run
With apologies for the lousy image; my digital cam doesn't do macro very well.
Now that I look at it, it seems as though I was a little more elaborate than I needed to be. I broke the brass tabs on both sides of the receptacle, then wired it as shown: one connection from the power cord to one side (call it side 'A') of one socket, a wire to connect side B of that socket to side A of the second socket, then a last connection from side B of the second socket back to the power cord.
For some reason I wanted the current flow across the two sockets to be in-phase rather than reversed-phase (well, it seemed like a good idea at the time), which is why the elaboration. But if one of the loads is just a lightbulb then breaking only one of the tabs and connecting the two power cord wires to the side the broken tab is on (one wire to each side of the break!) should do just as well.
He's got it exactly right.
If you are concerned about being "In Phase" then break one side or the other and on that side, the receptical side that gets it's "matching" color wire, (Black to Gold/brass, white to Silver and you are always good) is the one you mark for the plug of the device you are protecting, the odd matched side gets the plug in light bulb.
(BTW I'm the guy that first posted the setup that used the plug in resistor bulb into a duplex receptical, glad to see someone got good use out of the info...)
Another handy way ito set one up s to get an old fashioned screw in fuse holder (Yes they still srll them) and you can use that in series with a duplex receptical.
