APPLYING FEEDBACK MAKES THINGS BETTER!
I added a 300K "Schade" plate-to-plate feedback resistor between the 6V6GT and the 12AU7 driver and removed the 47uF cathode bypass capacitor from each of the cathodes of the 12AU7 (mu 20). Some initial measurement showed significantly improved frequency response, particularly at the low end and a quite significant reduction in overall distortion. The added plate-to-plate resistor raised the 12AU7 plate voltage from 85VDC to 115VDC.
The feedback also reduced the amplifier gain and sensitivity, of course; so much so that it was taking 2VRMS+ of signal to reach the clipping threshold, so I decided to change the driver to a 12AX7 (mu 100) after trying a 12AT7 (mu 60). I left the cathode resistor value at 1.2K for the driver (still unbypassed). At these conditions, the 12AX7 plate voltage was 210VDC and cathode voltage 1.5VDC, indication 1.3mA current draw for each 12AX7 section. Switching the driver tube reduced the overall B+ current draw by around 5 mA compared to that with the 12AU7 driver.
At these conditions, output power remained pretty much the same at the first sign of clipping at 3.25W into 8 ohms, 1 kHz single channel driven. Amplifier gain with the 12AX7 driver and was reduced from 16 dB to 12dB compared with the original design with the 12AU7 and no FB. In the new set up, the amplifier needed 1.3VRMS to achieve max output at 1 kHz, so the added gain from the 12AX7 got the amp back to a reasonable sensitivity level with the feedback applied.
Measurements were made and the following improvements were noted:
1. Low end frequency response improved considerably. 20 Hz response went from -7dB to -2.5dB and the rise to 100 Hz was more rapid with the 100 Hz response rising from -1dB to 0 dB. High frequency extension was also improved noticeably as well (see chart).
2. Distortion levels (THD+N) were greatly reduced across the spectrum, except for the very low end which rose a bit, presumably because of OP transformer limitations with the higher output at the lower frequencies. At 1W out, THD+N dropped at 1 kHz from around 2.7% to 0.3%, a reduction of 89%. I was pleasantly surprised to see figures well under 1% for this type of amplifier above 200 Hz at 1 W output.
Interestingly, one of the commenters on the Cascade Tubes page for his Marblewood build noted the identical 20 Hz response at -7 dB. He resolved the issue mainly by replacing the 10W 5K Edcor OP transformer with the 15W version (see above for the scan of the latter unit by THD+N).
I think the 12AX7 driver is happy at the operating conditions noted above; perhaps more so than the 12AU7, which was biased fairly cold in the original design, so I don't know if I need to fiddle with the 1.2K cathode resistors. Things look so good at 300K FB resistor value that I am not motivated to fiddle with this value further, either. Any thoughts?
SOUND
The amp retained good detail and sound stage without being harsh and the low end was definitely fuller with significantly tighter bass with 'blooming/tubbiness' reduced considerably. Listening continues to be very pleasant with various input sources and driven by my Fisher 400CX-2 pre-amp through my Klipsch Cornwall I's.
Here are the charts with the original 12AU7 driver/no FB compared to 12AX7 driver with 300K Schade resistor. Pay attention to the vertical axis scales, as they aren't same because of difficulty zooming the charts for the whole range of results. The frequency response looks much more like what I wanted/expected with the build.
Dave
Here's the THD+N vs Output Power post-Schade FB
