What makes you think they are bad ?Hi It appears my Pre out jacks are bad. It's not a broken solder joint on the board.
1. Does anyone have this part?
2. Are their excellent techs here who provide restoration on the M/C/T - 70 's??? What does it entail and idea of cost. Yes I know Legendary is an option.
That will work...but phono direct won't.IF I can't find the part I was going to swapped the "direct Phono" assembly to the Pre amp out....
Parts unit....Or upgrade to after market phono jacks.1. Does anyone have this part?
I guess desperate measures..."Legendary?"
All the switches on the C-70 are those darn slide switches that are damn near impossible to get clean without removing them and disassembling them.Question on the deoxit. Do you spray that into the switches on the C-70 preamp? over spray an issue?
They would probably be just as dirty as the switches he has presently.You still need parts? If so can go back in garbage bin to scrape parts for you. Just put it there earlier after they got collected.
