Yes. Its labeled on the top of the circuit board as 47.Caramba. Is 547 the one closest to the back of the unit?
TR547 needs to be removed. Its one of the two big heatsinked transistors.
That was quick. Do you know how to check a transistor with your multimeter ?It's out
looking at the front of the transistor the pins are BCE..
Measure the resistance between the collector and emitter both forward and reverse -- in the Ω's function.
Between Emitter and Base
Between Emitter and collector
13.22 ?13.22 (MM positive on B)
Both forward and reverseBetween Base and collector -- oops..![]()
Both forward and reverseBetween Emitter and Base
13.22 ?
See post # 55
OK.. that looks bad...On post 56. Both OL.
Post # 55 reading ? Emitter and Base ?
