Outstanding !!!I got it out!!!
Those switches are usually in pretty bad shape.Tape switch is even worse…
The volume/balance pot has reasonable access for spraying lube/cleaner.
Suggest try using a CDP or ipod/phone into AUX, same problem should exist
if it is the vol/balance pot. You thought that the issue was temperature
related which would rule out the vol/balance pot.
With amp powered off/unplugged, volume set to normal/faulty listening level
measure the resistance between the left IN/OUT wires on the volume board.
Repeat for the right channel. They should be the same, +/-20% worst case
hopefully less that +/-10%
The black wires are ground wires, not part of the audio path which is the White(left ch) in/out and Red(Right ch) in/out wiresThere is a 10%+ difference between white to black and red to black on the output coming from the volume board.
Suggest reflow the 4 sets of wires on the tone board, ie, red and white wires in white/red/brown/orange wrap and the corresponding wires on the volume board. Also inspect/reflow solder connections on vol/balance pot. Give vol and balance a good spray.I did run a 1k test tone through the AUX input. I had 1.7 or so vac on both channels coming off the function board, to the tone board/mode switch, then to the input of the volume board (orange covered leads). Then coming off the volume board (brown covered leads) the signal was much less (of course) and unbalanced e.g., left - 0.16vac, right- 0.23vac
Yes, less than 1 ohm. When I first did it I got a reading of 9.9k. I then moved the switch back and forth to make sure I had it in the right spot. I cleaned the volume pot really well with the green Deoxit Fader lube and still about 10% off.With amp powered off/unplugged, switches in normal positions, ie, MODE=STEREO, measure resistance between LI pin on tone board (white wrap) and LO wire(Orange wrap) repeat for RI and RO wires, expect less than 1 ohm.
Would point to main fuse at rear, check if blown. Should also check the 2 glass fuses on the power amp boards.I put the front face plate back on and then powered it up...got a buzz in the left channel and now no click or even the pilot light is dark
Yeah, 5A fuse blew! Of course, all I have are 2A, 3A, and 4A fuses right now...Would point to main fuse at rear, check if blown. Should also check the 2 glass fuses on the power amp boards.
Go with 4A, the 5A is more for full/rated power.
Need to work out why fuse blew, possibly a problem with the left channel power amp since buzz. Are power amp fuses ok?
Do you have a dim bulb tester? Do you know how to diode test the main/output transistors?
Wise to build the DBT rather than risk of doing further damage.
Nice graphic from markthefixer on diode testing, use diode function on MMView attachment 2465049
Try testing the output transistor in situ, see tabs on component side, looking for a c-e short, maybe b-e
