Just for completeness' sake. 14-gauge stranded copper wire has a resistance of 2.5 ohms per 1000 feet. So, that extra 4 feet = 0.010 ohms.Made some speaker wire from #14 AWG Romex SIMpull solid core wire, which I found 100+ feet at a garage sale for a couple of bucks. OCD made me keep both wires the same length, which meant about 4' extra wire length to one of the speakers.
Why 7 meters?
Sometimes it's the solderer and not necessarily the solder.But as we know, there is more to it than just resistance.
Oh, and I do use 5% silver solder for all audio connections.![]()
Me tooThe difference will be the different total inductance that the amplifier is driving (resistance, inductance, capacitance) due to the different wire lengths, which in theory can influence the sound.
Whether it is audible or matters at all is questionable, but I prefer equal wire lengths when practical. Not coiled, laid out straight in long loops is my method.
Yeah. I tried it once. Didn't really like it. I've used Kester "44" for centuries. Very reliable stuff, if the Monk's hands are steady.Yes, silver solder is very hard to work with and you can end up with lots of cold solder joints.
No a lead in this solder. And I have heard that less than 3% Ag is worthless. Mine is Kester with 95% Sn and 5% Ag.Silver added in a very small ratio to the lead/tin solder really doesn’t improve its conductivity much, … it is still MUCH WORSE than a direct mechanical connection.
You are prolly okay. After all, I'm not sure how precisely the voice coils in the speakers and the chokes in the crossovers are wound.I'm not going to say that I did it right, though I made up some speaker wires and with my setup the electronics are far from centered between the speakers, but I still made the cable lengths the same. That means that on one side most of the cable length is coiled up. I probably could have saved some cable by making them asymmetrical, but the cable I used was cheap enough. It least it would have saved me from that coil part of it...
It's going to be small.Yes. Some of my speaker cables are equal length, some are not... Honestly, I never noticed any significant difference, as far as I use 2x 2.5mm² sections.
In the case of excess lenght, the cable remains flat, I mean : not coiled nor wound, in order to avoid a possible inductance effect...
But it's me, OK ?![]()
T
