I used different meter today. My Fluke died about a month ago after only 24 years of faithful service.
Here is what I got:
Primary winding resistance is 1.2-1.3ohm
Secondary winding resistance one tap is 39.7ohm and another is 37.1ohm to grounded center tap.
Secondary AC voltage with rectifier pulled is 428vac each tap to ground.
Secondary AC voltage with rectifier installed and amp idling at 168ma is same - 428vac each anode to ground. (strange or indication of healthy PT reserve?)
All resistances and voltages on my drawing below are as measured with outputs set at 40ma draw (.400v across 10ohm 1% cathode resistors)
122vac from the wall.
Chokes on my drawing are of unknown specs and measured at .7ohm in series.
They are nearly 3x size of the ones that came with organ. Originals were getting hot and were buzzing measured 36ohm in series. As I remember, they lowered voltage slightly below 450v at close to specified output stage load.
Screen grid 100ohm resistors installed but I doubt they play any role here.
I'll be honest, PSUD2 is in Greek to me. I understand how all selected components affect the circuit but there is a lot of gray area for me. I'm not sure how to enter PT data, what capacitor resistance to choose or what choke parameters to enter. It seems like it was meant for engineers. I would probably get it if someone walks me through it. I definitely lack common knowledge here.
My fear is that chokes that would fit the bill here will be so huge that I won't be able to fit them in the chassis. Then what? Dropping resistor/capacitor input?
Thanks for your help, guys!
