Edit w/ answer: YES and my big Weller does it way faster than my smaller Hakko
I got away in my previous Magnepan repairs never to have to solder Aluminum, but those days are over. I have an MG-IIa with new wires glued on them which refuse to allow themselves to be soldered into place. I have spent the last few days searching for tips / clues.
http://www.integracoustics.com/MUG/MUG/tweaks/alex.html (mentions use of silver solder, while elsewhere I've found suggestions that silver solder does not work on Aluminum, e.g., https://www.practicalmachinist.com/...ng-and-fab/silver-soldering-aluminium-131405/)
http://www.integracoustics.com/MUG/MUG/tweaks/DavePride/ (mentions Al solder as if it's a breeze and easily available ... I have not found this to be true)
https://audiokarma.org/forums/index.php?threads/magapans.96835/ (ends w/ @pustelniakr summarizing how difficult it is, but not how to do it)
https://audiokarma.org/forums/index.php?threads/help-soldering-aluminum-magnet-wire.223629/ (the previous thread by @pustelniakr looking for advice on how to do it, and I imagine the genesis of his opinion on how difficult it is
http://db.audioasylum.com/cgi/searc...wmessage=&sort=score&sortOrder=DESC&forum=mug
https://www.audioasylum.com/cgi/t.mpl?f=mug&m=41262
Etc etc
I cannot find a definitive answer to the question, how do I solder new Magnepan aluminum wires? Most threads end with a statement that it's difficult, or that Magnepan used to supply the solder in the kits but no longer does, or something non-definitive about how actually do it.
So I turned to the Internet, have searched online for a few days and cannot find any aluminum solder kits that work with a soldering iron (I have found various (e.g.) that require a torch ... and I don't want my propane torch anywhere near the mylar).
One option is to remove the solder terminal and use a screw-type strip (which is, from what I gather, akin to what Magnepan themselves have done with newer models). However, the tweeter wire on MG-IIs needs to be soldered in a different place on the panel so a screw-terminal wouldn't work.
Could I please ask that someone who has successfully soldered new aluminum wires into Magnepans chime in with how you did it?
Thank you in advance for any guidance!
Etc etc
