Sounds about right , you didn’t state a price point just wanted a recommendation of a flexible cable.$300 for a 1 meter rca cable?
Audiofreak71
Hum and noise rejection.Dumb question time. Why would I used Coax cable to make an RCA cable. Shouldn't I use a different cable?
Ok, you are correct. I did not specify a price point. I think I am going to need to go the DIY route. It's pretty hard to justify (for me) spending $300 on 1m of cable when the Monorprice 1.5 ft cable costs less than $7.00 and doesn't give any issues, at least for me.Sounds about right , you didn’t state a price point just wanted a recommendation of a flexible cable.
Audiofreak71
I guess I didn't know as much as Coax as I thought I did. I assumed it was all stiff and rigid like the coax used for television. Live and learn.It can be very flexible, or not. There are many kinds of coax. The 1505F and W2964 are not at all like you're thinking for the TV coax that is both thicker and uses a solid, copper covered steel core.
Heck, I've used even just two conductors stripped from CAT5 cable, no shielding at all, and had no noise ingress that I could detect.
Big fan of the Mogami line of cables. Excellent build and quality, especially considering the price. 40 plus sets of Lynn Silver interconnects would get a bit pricey for me ... $12 a pair is more my price range and no complaints.
PS - tried the Monoprice cables here - pretty much useless. If you could get the wires to bend, almost had to hammer the connectors onto the jacks.![]()
I like the Knukonceptz Klairity Kable brand
Affordable and very flexible
Do you know the L & C values for that cable? I followed the link but couldn't find any.DIY cables could use standard 75ohm stranded antenna cable. Still seems a lot of unnecessary work when there's inexpensive cables available. And the Mogami's I mentioned earlier are a LOT more flexible than the antenna stuff.
Belden 1505F is flexible and has pretty decent LC metrics.
C=56pF/M
L=.31uH/M
DBTs have value, but are not the ultimate arbiter for me. Unfortunately, you cannot compare cables in a true DBT without adding another cable to the mix! If you're interested, I'll tell a tale of an inherently bogus test that some have advanced. For which measurements provide only laughter.Have L & C values been shown to make a difference in blind testing?
Not for the distance you're talking about.Have L & C values been shown to make a difference in blind testing?
I would consider using a longer cable, like a meter on instead of the one foot. Even a stiffer meter length cable will have enough length to bend more easily and is unlikely to be long enough to where signal loss over a 1 foot cable is likely to be an issue...
