yes. you'll get all sorts of answers based on some single fact, but if the original speakers
"did" frequencies below 200hz (yet another single factoid posing as mid-bass definition)
you can
1. stack them to lower the XYZ ( google is your friend - hint - frequency response)
2. get an amp to drive them (individually or as a single "sub-" "woofer")
3. an adjustable crossover or simply test the speakers for their response and fix the
crossover point
try it, most folks over-think many issues, and the OP is led into the weeds about
phase response, null points, cabinet resonance, blending the top and bottom,
running 4R into a standard receiver, isobaric conditions, etc (Guess what?
anybody even do this for car subwooferz?)
the first subwoofer I heard about 40 years ago (maybe 50) was the DQ1W attached
to the DQ10s, and with a particular recording, the subwoofer added warmth to the
music. I still abide by that rule.
today's subwoofers are used to rattle your fillings, and the test track is the opening
scene to Top Gun. I knew a guy who could shake his neighbor's basement glasses
and he was half a mile away. couldn't hear the music but the whole place shook.
good luck and if you're in the same timezone, file a prelim with the USGS.
