StormyT, I think you're on the right track with your research. However, I have to ask if you tested each rectifier tube prior to testing the results of that tube in the amp? Here's my belief; and it basically goes to the prior statement that amps DO NOT KNOW where they get their electrons from: Amps only know how many electrons they get.....and how fast they can get them!
So, to me, this is not necessarily about a 'brand'......it's about 'type' (as in the given 'specs' on a given unit.... AND.... if the individual rectifier itself is up to it's stated performance level. As Gadget somewhat make the point; a half dead rectifier can sound really crappy! What he admitted he did NOT do was to verify that, in fact, the rectifier was truly half dead! I think there's been some missing data in the past in that all these rectifiers being used in all these sound tests are, in fact, operating properly. The thing I've yet to see in ANY of these reported 'sound tests' is the results of the rectifier tests as an individual component. Not that it really matters, but I recent ran a number of my older tube rectifiers across my Hickok and I was really rather shocked at the results. Some of my "Good" rectifiers....as determined by being Mullards, GE, Amperex, or other 'brand-preferred' types....really were NOT all that good.....at least as far as the tube tester would indicated. SO....... if being used in some kind of rectifier shoot-out..... I believe this fact alone would skew the results to the unacceptable level....without ever really knowing it UNLESS the tube testing had been done. But, going back to the issue; If four GZ34s are all pitted against each other in the same amp with everything remaining the same EXCEPT the substitution of the rectifiers...... I would believe that if all four GZ34 had the same 'test' specs, then NO ONE would 'hear' a difference in any of them. On the other hand, if the results of tube testing revealed some difference in either voltage or current delivery, then perhaps 'yes'.....an audible difference might be noticed, particularly if the test were done at the limits where the tube differences would show up, like in louder volume levels.
Anyway...... MARK!!!...... I think you have a really great approach to your builds, and I envy your knowledge of PS construction. So much so in fact that I plan to lean on you for my next build....which I hope to begin some time this fall. Nothing too dramatic.....but I have some old iron around here and I'd like to do a pair of mono-blocks....either from an old pair of Scott amps, or from some old Sherwood; with the former being 6L6 based and the latter being EL84 PPP.
Anyway....... CRAIG...... If you start selling dishwashers with internal 117 VAC outlets......or Stand UP bath tubs....and use my 'controversial thread' as a soap box, I wet-noodle lash you until you say 'uncle'.........lol.
All good commentary here......and while the subject may have been covered many times previously...some of the comments here are really VERY educational, and I hope will do more than just me some good! WC
