OK, interesting that you are the second person that has asked about CT-80's in the last 48hrs. But first, about the Karat 300s.
I've owned or heard all around the K-300, but have not listened to them. But after listening to LE-600, Quinto 510, 520 & 530, Karat 200, Karat 60 and CT 80 I think that I can make a pretty educated guess about the Karat 300. And that would be that I think that they fit right into a pretty sweet spot size wise, and am guessing that they sound very good. I do have to admit to a bit of a bias in that I do prefer acoustic-suspension speakers over bass-reflex.
Concerning the CT 80. First, and this is important, they were made for 2 years, with revisions happening every 6 months. The very first revision has the same size cabinets as the later 3 but are closed boxes, they do not have a port and use different woofers (3125 vs 4903). The later 3 revisions have a port in the front, to the right of and between the woofer and mid. The port is under the velour material covering the face and is hard to see.
I had a pair of them here for testing last month, they were the closed box version. My friend has owned them for several years and has complained since shortly after buying them that they have a very overdone and boomy bass, and that if he turned them up "the woofers start to flutter". And they do.
We have had them hooked up to 3 different amps and 3 different cd players and the woofers are resonating badly. They have been recapped and all of the crossover components checked. We tried a tested replacement CT 80 crossover in one box. We replaced a woofer with a tested correct 3125 woofer. We checked all cabinet seams and added a bead of glue on the inside. We cut new closed cell foam driver seals. None of that helped at all. The speakers sounded like crap.
The only think that helped was to add more fiberglass cabinet filling. Originally they were about 2/3 full, I added bats until they were completely filled. This helped a fair amount but the woofers are still resonating somewhat and the bass doesn't sound very good. These are the first pair of Canton speakers that I have listened to that I can not like. I sold my friend my Karat 60's for a very nominal sum and he is completely happy with them, they are in fact very fine sounding speakers. I am still baffled by the CT 80s. My feeling is that the cabinet is far too large to act as an acoustic suspension and that they are acting more like an infinite baffle with not enough woofer control. Note that the amps used were my friends Yamaha AX-700 & AX-750 (recapped) both with 110wpc and my MX-1, so having enough power to control the woofers or enough damping factor didn't play a role.
Note again that the above comments only apply to the first revision of the CT 80. Having seen the schematics for the CT 80 and 90 I see that both of them had an initial version with a 3xxx series woofer that was changed to a 4xxx series with the follow-up revisions. I have not heard the later versions but believe that they probably sound much better. Our member
morfeora has a pair of CT 90's and loves them. I am not meaning to globally trash the CT 80, just passing on my puzzling experience with one pair. But I'd be real careful to find out which revision they are before considering buying them.
I'm including a photo found on the web that just barely shows where the port is on the ported versions.
Cheers,
James
